[Official Beta] AMAS (ASUS multiple Access-point system) beta test starts now
ASUS-OP
What is AMAS?
AMAS (Temporarily name) is ASUS Multiple Access-Point System, the core feature is to combine ASUS powerful routers to form a whole home coverage WiFi system with centralized control just like a MESH network. This means you can simply purchase more routers to co-work with your existing routers for this effect, putting your investment to best use. Better yet, you won't loss any fancy and advanced features, such as AiProtection, Adaptive QoS…etc. all features will be supported, just the way you are!
Details below:
https://www.snbforums.com/threads/official-beta-amas-asus-multiple-access-point-system-beta-firmware...
Note: At we are still in the very early stage of development, you will be trying out these beta firmware at your own risk.
Please make sure you understand how to do firmware recovery for your device before attempting to test drive these new firmware.
ASUS-OP
Update from Wilson_Deng from the original post:
(09/22) New beta available today for RT-AC86U, RT-AC68U
- Improve system stability
https://drive.google.com/open?id=0ByEpTc0fDkeqZ21wbTFCeVZoa2M
(09/15) New beta available today for RT-AC68U, RT-AC86U, RT-AC5300, RT-AC88U.
https://drive.google.com/drive/folders/0ByEpTc0fDkeqZUR0dGtSR1o0OE0?usp=sharing
And now we make it a official name as AiMesh.
Here are changelogs
For RT-AC86U, RT-AC68U
1. UI
- Change AMAS to AiMesh.
- Change alogorithm for onboarding progress % count.
- Add reset modem page into QIS.
- Add some hint for user when DHCP Server and wireless authentication type changed.
- www: change the position of separating the ssid of wireless bands checkbox.~~~~~
- www: accroding to QIS 3.0 SPEC, divide WAN selection into 2 steps.
- [Update][AiMesh] www : Modify AiMesh naming.
- AiMesh system.
- Cap : AiMesh router.
- Slave : AiMesh node.
2. Enabled Roaming Feature at default setting.
3. New Sync Configuration
- Telnet
- SSH
- Roaming assistant
- Smart Connect
- MAC Filter
- Syslog
4. Auto reset default when onboarding failure.
5. Add renew ip mechanism in RE mode. [Bug#244]
6. Fixed an issue as RE can be onboarded after user login by IPAddress/index.asp.
7. RE can't be search after on-boarding failure by CAP.
8. Other miner bugs fix.
For RT-AC5300, RT-AC88U
First beta release.
Official Site ready:
https://www.asus.com/aimesh/
