08-25-2017 06:59 PM - last edited on 03-05-2024 09:38 PM by ROGBot
08-25-2017 07:29 PM
08-25-2017 07:40 PM
legendarypoet wrote:
Have you tried updating to the latest BIOS, or is it still the factory BIOS?
08-26-2017 01:55 AM
Raja@ASUS wrote:
The latest build is 9910. Its the one at the top of the sticky thread.
08-26-2017 12:41 PM
08-26-2017 07:11 PM
starlightknight wrote:
I started putting together my build last night and faced the same issue. I am using 8x16GB Crucial Ballistix modules. I couldn't boot with all 8. After much frustration, I went through the modules 1 by 1 in the slot order recommended in the manual, powering it on between each dimm to isolate the issue. The board seemed ultra sensitive to how they were seated compared to any other board I've built in the last 15 years. I had to re-seat multiple modules multiple times otherwise I got the same behavior you originally described - " OLED displays 'memory' for a few seconds, then the system automatically resets and keeps doing this in an infinite loop"
Fortunately after about an hour of fiddling with it, it worked. Maybe trying seating them one-by-one and retrying if it fails. Worked for me at least.
08-27-2017 02:22 AM
08-29-2017 12:47 AM
