Results 1 to 10 of 10
    ROG Guru: Yellow Belt Array Cory29 PC Specs
    Cory29 PC Specs
    MotherboardROG Zenith extreme x399
    Processor1950x
    Memory (part number)G Skill F4-3200C16-8GTZ - 64gb
    Graphics Card #1GIGABYTE GeForce GTX 980 Ti WF
    Monitorcintiq 22hd touch
    Storage #1Sam SSD 850 EVO 1TB
    CPU Coolerxspc block - D5 - 3x120 slim rad
    CaseView 71 (doesn't fit board)
    Power SupplyEVGA supernova 1000G3
    Keyboard K95
    Aug 2017
    131
    will a capacitor not stamped down cause me issues ?
    This is my second board first one was rma because the box cut into the IO shield
    my new board has a capacitor (im assuming its a capacitor) that isn't seated correctly by the ram
    there is also a few pins at the bottom for jumpers that were soldered at different angles
    should I rma for the capacitor idk if its something that would cause an issue when i try to overclock my ram or if i should see an error or not already
    - so far it boots
    ROG Guru: Black Belt Array Korth PC Specs
    Korth PC Specs
    MotherboardASUS X99 R5E (BIOS2101/1902)
    ProcessorHaswell-EP E5-1680-3 SR20H/R2 (4.4GHz)
    Memory (part number)Vengeance LPX 4x8GB SS DDR4-3000 (CMK32GX4M4C3000C15)
    Graphics Card #1NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Graphics Card #2NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Sound CardJDS Labs O2+ODAC (RevB), USB2 UAC1
    MonitorASUS PG278Q
    Storage #1Samsung 850 PRO 512GB SSDs, 4xSATA3 RAID0
    Storage #2Comay BladeDrive E28 3200GB SSD, 8xPCIe2
    CPU CoolerRaijintek NEMESIS/TISIS, AS5, 2xNH-A14
    CaseObsidian 750D (original), 6xNH-A14
    Power SupplyZalman/FSP ZM1250 Platinum
    Headset Pilot P51 PTT *modded*
    OS Arch, Gentoo, Win7x64, Win10x64
    Network RouterActiontec T3200M VDSL2 Gateway
    Accessory #1 TP-Link AC1900 Archer T9E, 1xPCIe
    Accessory #2 ASUS/Infineon SLB9635 TPM (TT1.2/FW3.19)
    Accessory #3 ASUS OC Panel I (FW0501)
    Korth's Avatar
    Mar 2015
    152
    2,719
    I'd run exhaustive memory burn-in/stress tests. Especially if memory is faster than JEDEC and/or CPU is overclocked.
    And I don't know ASUS policy in detail, but I would personally expect RMA/warranty to cover this sort of motherboard defect (component not properly soldered on board, doh).
    [/Korth]
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600
    Memory (part number)16GB DDR4
    Graphics Card #1GTX980
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    294
    7,346
    If it's a through-hole soldered component then you should be able to see if there is a bead of solder on the back of the board at that point. If it's completely soldered then it doesn't matter if it's not completely flush. As long as there is a good connection it will work.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    Cory29 PC Specs
    Processor1950x
    Keyboard K95
    Aug 2017
    131
    I can't see the back too well its covered by the back-plate i see the 2 pins sticking through
    I'm having issues trying to get the ram to run at any speed past 2133 (im guessing its unrelated)
    the lighting also doesn't work after i updated all the drivers and software so im guessing its a bug
    xeromist PC Specs
    ProcessorAMD 2600
    CPU CoolerWraith
    xeromist's Avatar
    Jul 2010
    294
    7,346
    Yeah, you may want to start a new thread regarding your memory speed. It's going to depend a lot on the specific memory kit you bought and how many sticks you are trying to run as some work better than others. It's also possible that you have some flawed memory or a weak memory controller. You might be able to go higher with some manual tweaking.
    Cory29 PC Specs
    Processor1950x
    Keyboard K95
    Aug 2017
    131
    I think I'll wait for new bois update
    I've been playing with the beta today and its able to hit the correct speed off the bat, but windows is bluescreening every 15min to an hour with a random issue so ill roll back the lights still don't work (the error is always different in windows )
    thanks everyone
  7. #7
    Tech Marketing Manager HQ Array Raja@ASUS's Avatar
    Apr 2011
    161
    7,454
    1) make sure you update the aura/oled firmware. It is linked in the uefi sticky thread within this sub-forum.
    2) Try using a 2T command rate for your memory.
  8. #8
    ROG Guru: Blue Belt Array gupsterg PC Specs
    gupsterg PC Specs
    MotherboardAsus Maximus VII Ranger
    Processori5 4690K
    Memory (part number)HyperX Savage 2400MHz 16GB
    Graphics Card #1Sapphire R9 Fury X (1145/545 Custom ROM)
    MonitorAsus MG279Q
    Storage #1Samsung 840 Evo 250GB
    Storage #2HGST 2TB
    CPU CoolerThermalRight Archon SB-E X2
    CaseSilverstone Temjin 06
    Power SupplyCooler Master V850
    Headset/Speakers HyperX Cloud
    OS Win 7 Pro x64 / Win 10 Pro x64
    gupsterg's Avatar
    Feb 2015
    79
    840
    Quote Originally Posted by Cory29 View Post
    - so far it boots
    Only my take.
    Personally I would RMA board. At the price of what these boards are nothing but perfect 'out of box' would do for me. Even on a lower priced board it would be unacceptable to me.
    Regardless of board working I view things like this on a resale value angle. Whenever I view an item on 2nd hand market that I maybe interested in, I always check to see if components look right. How I see it is I'm less likely to have something turn up which causes me issues.
    Intel Defector AMD Rebel
    TR 1950X - Custom WC - Asus Zenith Extreme Alpha - G.Skill Trident Z 3400MHz C14 QC - RX VEGA 64
    R7 2700X - Custom WC - Asus Crosshair VII Hero - G.Skill Ripjaws V 3533MHz C14 DC - Sapphire HD 5850 Toxic
    24/7 OC: i5 4690K @ 4.9GHz CPU@1.255v 4.4GHz Cache@1.10v - Archon SB-E X2 - Asus Maximus VII Ranger
    Sapphire Fury X (1145/545 ~17.7K GS 3DM FS)
  9. #9
    Banned Array JustinThyme PC Specs
    Laptop (Model)G752VY-DH72
    MotherboardRampage VI Extreme
    ProcessorI9 9940X
    Memory (part number)64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17
    Graphics Card #1ASUS Strix 2080Ti O11G @ 2.1GHz
    Graphics Card #2ASUS Strix 2080Ti O11G @ 2.1Ghz
    Graphics Card #3ROG Nvlink
    Graphics Card #4Have to feed animals
    Sound CardExternal Audioengine D1 24 bit 192kbps DAC
    MonitorASUS PG348Q @ 100Hz
    Storage #1Intel 905P 480GB U2 flavor
    Storage #2Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1
    CPU CoolerHeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS
    CasePhanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM
    Power SupplyCorsair AX 1500i
    Keyboard ASUS Claymore
    Mouse ASUS Spatha, Logitech MX Master
    Headset Sennheiser HD 700
    Mouse Pad ASUS ROG Sheath
    Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub
    OS Win10 Pro 1809
    Network RouterNetGear NightHawk X10
    Accessory #1 NetGear Prosafe 10GBe Switch
    Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
    Nov 2013
    144
    3,859
    Does it work? Y/N
    Y......you are good to go
    N......RMA
    Proper seating of capacitors or other components means the leads, which are horrendously long before trimmed, are through the board and soldered on the back side. The rest is purely aesthetic. When you RMA anything its up to the manufacturer of whether or not you get a new board. 99% of the time that's a resounding no and depending on the manufacturer you may get a refurb out of the pool sent to you as a replacement that's even worse looking with your board added to a repair cue or they may put you directly in a repair cue that takes a lot longer for turn around and no guarantees on aesthetics when you get it back.
    First line of defense on anything that comes out of a box damaged it return it to the point of sale and get another.
  10. #10
    Cory29 PC Specs
    Processor1950x
    Keyboard K95
    Aug 2017
    131
    I returned it back to newegg. It would wiggle like a loose tooth and I could see black stuff on the pins at the base. If only it didn't take newegg 8-11 days to create a replacement guess I learned the hardway
