08-27-2017 10:25 PM - last edited on 03-05-2024 10:03 PM by ROGBot
08-27-2017 11:46 PM
08-28-2017 08:38 AM
kwaka wrote:
Very good question. Sorry I don't have the answer as have a similar question.
Will tag your post for future info.
Z270F mobo and Kraken x62 + 2 rad fans will be the config I use.
Not sure if the pump goes in the AIO_header or not. Also if cpu_fan header should be used with a splitter for both rad fans.
Hope somebody can help you out with your answer, in turn giving me some in sight for my build when I get time to do it.
08-28-2017 08:57 AM
08-28-2017 11:19 AM
Chino wrote:
Try looking inside your BIOS to see if you can control the fans connected to the H_AMP_FAN header. If so, go for it. As for the CPU_FAN error, you can disable it.
08-28-2017 02:54 PM
Ollion55 wrote:
I don't know if the AIO_PUMP header can detect a not spinning pump fan.
