bah! g751jy dead dvd drive. BR replacement?
Weirdoutworld
So my DVD drive just up & quit responding. No light, no movement empty or with a disc, no disc logo next to the cursor when closing. I was able to open it using a paperclip in the reset hole & get my disc out. But...*
If I order a Blu-ray player instead if the stock DVD *is it just "plug & play?".*
The actual hardware replacement isn't a problem BUT...
**Anybody care to elaborate on what what I need to do or the drivers I need to get installed to get either DVD or bleray running again?
Not_Enough_Rage
Level 11
The players are plug and play. If you get a Blu-Ray player you will need to get software to play the Blu-Ray discs. Such as Power DVD 17 for example. DVD`s will play with out the software.
NeoBeum
I'll sell you my spare if you sell me your drive bezel
get the Windows store blurayplayer, the xbox official one
