VG248QE Sound
Alexander_K_
Hello, On the 20th of August i got the VG248QE Monitor With this monitor i got a Black and Green ends Cable for Audio ports.
I'm pretty Sure that i got a bad Audio quality... Can someone please help me with this problem.
Thanks,
Alex.
MasterC
Community Admin
Community Admin
Hi Alexander,
You can try to play the sound through HDMI or DisplayPort, the sound quality is better and it's one less cable to manage. If you still want to use the 3.5mm audio cable, try connecting it directly to the motherboard or sound card rather than using the front audio jacks on your desktop (that might be the issue).
_____________________________________________________________
FPS, Racing, and VR Gamer / Tech Enthusiast / ROG Admin
