09-01-2017 04:05 AM - last edited on 03-05-2024 10:02 PM by ROGBot
09-01-2017 05:36 AM
pisymbol wrote:
At idle, my CPU temperature was round 30-31C. I flashed 9960 and now it is reporting it is 57C! Huh?
EDIT: Reverting back to 9910 fixes it.
09-01-2017 06:47 AM
09-01-2017 07:52 AM
Mikan02 wrote:
I mentioned this in main thread. I think it shows CPU package, you can still see CPU diode in some monitor software like AIDA64.
CPU package can easily get very hot and pass limit before any core does, since there is so many.
Also I do not think package have offset only diode, but I might be wrong thou I been trying to keep package below limit without offset.
One reason for change is cause package temps just as important as diode, even more if it does not have offset.
Another reason could be compatibility, but my guess is on first.
There are actually two package temps I think, since it is two CPU in one. Not all monitor software show both for some reason.
I tried to install LiveDash software again, cause I wanted to see if I it was possible to change to several sensors again.
First time I tried it I had it swap between CPU temp, voltage and speed.
For some reason software crashes on launch now, I do not know if it is cause firmware change or something else.
Hopefully Asus have a look at it when possible. 🙂
09-01-2017 06:47 PM
09-02-2017 09:31 AM
