Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    ROG Enthusiast Array bfollowell PC Specs
    bfollowell PC Specs
    MotherboardASUS ROG Maximus IX Hero
    ProcessorIntel Core i7-7700K
    Memory (part number)G.SKILL TridentZ Series 16GB DDR4 SDRAM DDR4 3200 (PC4 25600) F4-3200C16D-16GTZB
    Graphics Card #1ASUS ROG Strix GeForce GTX 1080 OC edition 8GB 11Gbps ROG-STRIX-GTX1080-O8G-11GBPS
    Sound CardSound BlasterX AE-5
    MonitorASUS ROG Swift PG279Q & ASUS VW246H
    Storage #1Samsung 850 EVO Series 500GB 2.5" Solid State Drive
    Storage #2Western Digital Black Series 2TB 3.5" 7200RPM Hard Drive
    CPU CoolerNZXT Kraken X61
    CaseCorsair 750D
    Power SupplyEVGA 750 G3
    Keyboard Logitech G710+
    Mouse Logitech G602
    Headset Kingston HyperX Cloud Pro
    Headset/Speakers Logitech G​51 Surroun​d Sound 5.​1 Speaker ​System
    OS Windows 10 Home 64-bit
    Network RouterLinksys WRT3200ACM
    Jan 2017
    64
    Can't get 5.1 Surround out of my Maximus IX Hero
    OK, I'll freely admit that I have no experience with onboard sound. I've had a discrete sound card in every computer I've build since 1993. I say that to clarify that I'm probably doing something really stupid or missing something really obvious.
    Anyway, even though I have all five of my audio cables correctly and firmly connected to my motherboard, all I seem to be able to get is Stereo, 2.0 sound. I don't even see a spot where I can change speaker configurations from 2.0 to 4.1 to 5.1, etc., let alone test the different configurations like I'm used to seeing in the Creative sound control app and like I've seen in videos for earlier versions of the Realtek software.
    Like I typically do, I didn't even open the driver disc that came with my board. I'd already downloaded all of the appropriate drivers from the hardware manufacturer sites and installed the latest drivers from there. The only things that I seem to have, control panel-wise for the ROG SupremeFX Realtek S1220, is Sonic Studio III and Sonic Radar III. Am I missing something? I've been wandering around in Sonic Studio III looking for what I need, but, at least for me, there just isn't anything there. It really seems as if this control panel is missing half of what I need or that I'm just missing the correct control panel software altogether.
    Any ideas?
    Thanks.
    ROG Guru: Grand Master Array
    Oct 2012
    339
    15,247
    Open the SupremeFX control panel and there should be an option called Speaker Configuration.
    bfollowell PC Specs
    CaseCorsair 750D
    Mouse Logitech G602
    Jan 2017
    64
    There is no SupremeFX Control Panel, at least that I can find anywhere. It wasn't installed when I installed the latest Realtek audio driver from the Asus support page. All I have, audio related, are Sonic Studio 3 and Sonic Radar 3, and neither of those have any sort of speaker configuration options.
    Is there any special place I may go to look for the SupremeFX Control Panel, other than looking in my start menu for something starting with or including SupremeFX? Because it isn't there.
    Thanks.
    ROG Guru: Gold Belt Array Menthol PC Specs
    Menthol PC Specs
    MotherboardM 10 Apex / XI gene
    Processor8700K / 9900K
    Memory (part number)2x8 Gskill Trident Z 4266/2x2x8 Gskill Trident Z 4500
    Graphics Card #1RTX 2080ti / GTX 1060
    Sound CardSoundBlaster Ae5 / Onboard
    MonitorBENQ 32" 4K
    Storage #1Intel 900p 480GB/Samsung 960 Pro 1TB
    Storage #2Intel 750 1.2TB/Plextor 1 TB 2X 950 Pro
    CPU CoolerCorsair H150i AIO / H1110i
    CaseCorsair 740 ? Lian Li Air
    Power SupplyCorsair AX 1200i / AX 1200i
    Keyboard Corsair
    Mouse ASUS Strix
    Headset HyperX Cloud Alpha
    Mouse Pad ASUS
    Headset/Speakers Logitech Z906
    OS 10 X64 Pro
    Network RouterVerizon Fios
    Accessory #1 Intel Wifi BT pcie card
    Accessory #2 Red Bull
    Accessory #3 English Breakfast Tea
    Menthol's Avatar
    Jan 2012
    241
    4,548
    There is no difference between how an add on sound card and on board sound works, there is typically 3 analog sound cables for 5 way speakers, front, back, center/sub, connect them the same way
    If you go to Windows control panel, speakers, configure, you should be able to configure, 2 way - quadrophonic - 5.1 - 7.1 speaker systems the same way Chino said for the SupremeFX software
    Nate152 PC Specs
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Power SupplyPCP&C Turbo Cool 1200w
    Mouse ROG Chakram Core
    Mouse Pad Steelseries QCK Prism XL
    OS Windows 10 Home 64 bit
    Nate152's Avatar
    Feb 2013
    308
    16,463
    At the bottom right of your screen click the arrow pointing up, then double click the speaker.
    bfollowell PC Specs
    CaseCorsair 750D
    Mouse Logitech G602
    Jan 2017
    64
    Menthol & Nate152, thanks to both of you. Yes, I had already figured out that I could change speaker configurations for my speakers, headphones, etc. using the regular Windows options. My problem was that I couldn't find the SupremeFX control panel that I was expecting to find. Thanks Nate152 for steering me to the speaker icon in the overflow area of the taskbar. It would never have occurred to me to double-click there to open the SupremeFX control panel. That got me what I wanted.
    It still seems strange that there isn't a Start menu option for this, and that this is the only way to access this control panel though.
    Still, this took care of me.
    Thanks again guys.
  7. #7
    Oct 2012
    339
    15,247
    Essentially, the SupremeFX control panel is like a revamp of the Realtek one. So they even share the same icon.
  8. #8
    bfollowell PC Specs
    CaseCorsair 750D
    Mouse Logitech G602
    Jan 2017
    64
    Well, mine doesn't have an icon, unless you mean the speaker icon in the overflow area at the right of the task bar, because I don't have a Start menu option for this. The only way I can get to it is by clicking on the speaker app in the overflow area. I can get to it though, and that's the main thing.
    Should there be a Start menu group/option?
  9. #9
    Oct 2012
    339
    15,247
    When you install the Realtek drivers from the ASUS website, you should see this icon in your system tray. Unfortunately, this is the only way to access the SupremeFX control panel.
  10. #10
    bfollowell PC Specs
    CaseCorsair 750D
    Mouse Logitech G602
    Jan 2017
    64
    OK, thanks for confirming Chino. It looks like everything installed correctly then. It's just that, after twenty years of Creative sound cards on Windows systems, I'm used to a separate control panel app with it's own icon in the Start menu so, when I didn't see that, I just assumed something hadn't installed correctly.
    Either way, I'm planning on picking up a Creative Sound BlasterX AE-5 around Black Friday/Cyber Monday, so onboard sound is really just a temporary place holder anyway, just like the GTX 1050 I pulled out of another system until I get my Asus ROG Strix GeForce GTX 1080 OC edition 8GB 11Gbps GDDR5X in a week or so.
    Thanks again for all of your help. I really appreciate it.
