Results 1 to 4 of 4
    New ROGer Array
    Jul 2017
    2
    ASUS OC Panel II dead after firmware update in Maximus VIII Extreme
    Hello!
    As mentioned in the title; the panel is dead. I did get digits on the screen before i updated the fw, so i suppose the the panel was working before (new PC-build, the first thing i did was to get all the latest software and fms). Has anyone else had this problem, or know if there are a way to fix it?
    Best regards Adam
    ROG Guru: Grand Master Array
    Oct 2012
    339
    15,255
    Are you positive that you flashed the OC Panel II with the correct firmware? There have been cases where users are using the Front Base firmware instead.
    New ROGer Array
    Jul 2017
    2
    Quote Originally Posted by Chino View Post
    Well, i am almost 100% sure that i used the right firmware.
    ROG Enthusiast Array Muddy Paws PC Specs
    Muddy Paws PC Specs
    Laptop (Model)whats a lap top, a sleezy dance
    MotherboardAsus Crossair vi hero
    ProcessorRyzen 1800x oc'd
    Memory (part number)Corsair 2666mhz@2933mhz
    Graphics Card #1Asus duel 6g gtx 1060 oc'd
    Graphics Card #2nope
    Graphics Card #3nope
    Graphics Card #4nope
    Sound Cardon board Asus
    MonitorAOC 29" wide screen
    Muddy Paws's Avatar
    Jul 2017
    28
    http://https://www.dropbox.com/s/och...-0204.H00?dl=0
    try one of these use the firm ware up dater in the oc folder ROG OC Panel FW_v1.0.3.2.exe
    it can be fixed I had the same problem and I got mine back
