Results 1 to 6 of 6
    ROG Guru: Green Belt Array Rob W. PC Specs
    Rob W. PC Specs
    MotherboardRog Asus Rampage vi extreme
    ProcessorIntel i9-7980x Oc 4.6ghz 24/7
    Memory (part number)64 gb GSkill 3600mhz (8x8) 15,15,15,35
    Graphics Card #1nvidia Titan V + ekwb custom loop
    Graphics Card #2nvidia RTX 2080Ti on air.
    Sound Cardonboard?
    MonitorIAsus PA329Q 4k 32"
    Storage #1samsung SSD 960 EVO 250 GB. M2 nvme
    Storage #2Samsung ssd 970 evo 500gb m2 nvme
    CPU CoolerEKwb custom loop
    CaseCorsair Obsidian 900
    Power SupplyCorsair HX1200i 1200w
    Keyboard Logitech G910 orion spark
    Mouse Logitech G502 Proteus core
    OS Win 10
    Network Routerbt infinity super fast.
    Accessory #1 Seagate Barracuda 2 TB HDD
    Accessory #2 Aqeuaro 6xt fan controller
    Accessory #3 Intel Optane 280gb
    Dec 2015
    104
    501
    gpu temps problem
    Solved.
    Hi all.
    I have a problem with my gpu temps randomly going from 50ish to over 90 deg.
    I have my cpu running at 4.6 ghz, it maintains a good 54 deg gaming and will max at 64deg.
    my gpu I have running at 1533 htz , memory clock at 2,000htz , normally this games at around the 54deg but will randomly shoot up to over 90 deg ,
    I can play the same game 10 times and its fine and then it goes crazy, it might happen just once in a week and sometimes not at all.
    I am wondering if this could be related to other software running at the same time, I have CAM software for the kraken x62 running as well as gpu tweak and Msi Afterburner.
    I use Afterburner for on screen display and video capture.
    GPu tweak for OC and fan control.
    CAM is used to control cpu pump and fans.
    the trouble is all three monitor components and temps, not sure if they are conflicting or not.
    I disabled Cam in my firewall traffic, also I sometimes have TS3 running.
    I have uninstalled AL suite and tried reinstalling Gpu tweak, also put GPU at normal OC setting but it seems to run hotter at this settting as if the fans are not cutting in ( I hear them when they do lol)
    If it helps, here's sceenshotsClick image for larger version.
    if anyone has any ideas it would be great, I am getting close to a complete rig reinstall.
    **Note** Ihave all the latest drivers and Bios installed.
    Moderator Array
    Jul 2016
    12
    212
    That's interesting... That your card will spike up to 90degrees. Have you tried this card on another PC to see if it still happens, so we can eliminate software/hardware issues.
    Rob W. PC Specs
    Sound Cardonboard?
    OS Win 10
    Dec 2015
    104
    501
    hi.
    I don't have access to another machine so cant try gpu there, over a couple of days gpu seemed to get worse and worse for spiking.
    I have been doing some more investigating and in an effort to resolve it I completely wiped rig and reloaded win 10 and all drivers, it seemed to work temps now stay in the low 50s whilst playing Star Citizen, that's good! but when I load any steam games card goes haywire and no matter if fans are on max temps just keep rising, over 90 deg before I am able to close game, Latest one tried was "pugb" temps just shot up as soon as I hit play.
    card runs ok with everything else so I am not sure if I need to alter game settings to keep it lower but it does seem o be prominent when steam is loaded.
    EDIT: In hindsight these problems only started happening after installing the Kraken X62 and its software, prior to that I had no temp problems.???
    Moderator Array
    Jul 2016
    12
    212
    That's really interesting... Steam games shouldn't cause this issue. If you could, you should try this card on a friend's computer to see if it's an isolated issue.
    ROG Enthusiast Array Otets PC Specs
    Otets PC Specs
    MotherboardAsus x299 Deluxe
    ProcessorIntel Core i7 7820x
    Memory (part number)G.skill tridentZ 3200mhz(c14) 32GB
    Graphics Card #1Asus GeForce 1080 A8G
    Storage #1Samsung m.2 960 pro 512gb
    Storage #2Samsung ssd 850evo 250gb
    Power SupplyCorsair rmi 1000w
    Keyboard Razer BlackWidow Chroma
    Mouse Razer Chroma Mamba Tournament edition
    Headset Razer Tiamat 7.1
    Mouse Pad Razer Firefly
    OS Windwos 10
    Network RouterMikrotik 951G
    Sep 2017
    38
    a similar problem. win10 + asus 1080A8G
    a temperature of 90 in any game. even in the GPU-Z, the rendering test heats up to 90. re-installed the 3 driver versions from the nvidia site. without result.
    put the draver from disk to vidiokarte, and normally earned.
    Also in the system is installed msi afterburner. Maybe it's all the same, does it work that way?
    I was trying to rearrange the video card in the 2nd slot pciE on the board. I installed windows. I installed the latest drivers from the site nvidia. and the same thing, 90 degrees!
    Rob W. PC Specs
    Sound Cardonboard?
    OS Win 10
    Dec 2015
    104
    501
    Solved!!
    re installed o/s, all drivers, got rid of alsuite and hwinfo, unchecked other software from monitoring system, all seems OK since, cpu now running at between 19 to 35 deg and Gpu now 35deg on steam games, 55 deg on star citizen with no major spikes,
    just thought I'd let you know, thanks.
