Page 1 of 5 1 2 3 ... LastLast
Results 1 to 10 of 41
    ROG Member Array danegeld PC Specs
    danegeld PC Specs
    MotherboardMaximus IX formula
    Processor7700k
    Memory (part number)corsair 3200RGB (32g)
    Graphics Card #1EVGA SC2 hybrid 1080ti
    MonitorASUS ROG swift PG279q
    Storage #1samsun 960 pro 512
    Storage #2WD black 1tx2 raid 0
    CPU Coolercorsair 110i
    Casecorsair 900d
    Power Supplycorsair AX1200i
    Keyboard microsoft
    Mouse M570
    Headset/Speakers Klipsch 2.1
    OS Win 10 pro
    Network RouterASUS RT-AC5300
    danegeld's Avatar
    May 2017
    24
    memory and CPU help please
    i bought a computer was supposed to be 15% OC or more and tested stable for 72 hours... i kinda think that its only 10% also i dont think the memory is runinng at 3200...i looked at a few other threads i think i have it set the same...but ???
    https://valid.x86.fr/6crj53
    Nate152 PC Specs
    Memory (part number)16GB G.Skill Trident Z 4000MHz 16-16-16-39-2T
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba OCZ VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Power SupplyPC Power & Cooling Turbo Cool 1200w
    Mouse Logitech G500
    OS Windows 10 Home 64 bit
    Nate152's Avatar
    Feb 2013
    308
    16,353
    Hi danegeld
    Welcome to the ROG forum !
    That is a very nice pc you have.
    I see your i7-7700k is overclocked 100MHz to 4.6GHz and your 32GB of ram is running at 2933MHz.
    What is it you'd like to do ?
    danegeld PC Specs
    Processor7700k
    Casecorsair 900d
    Keyboard microsoft
    Mouse M570
    OS Win 10 pro
    danegeld's Avatar
    May 2017
    24
    id like the memory to be at 3200 and the Cpu to be about 4.8 (well id love 5.0GHz but i dont want to over do it) wondering if maybe i should just hit the EZ oc thing and let it do the 17% it says it can auto do. but would that harm my system?
    Nate152 PC Specs
    MonitorHP ZR30w
    Mouse Logitech G500
    Nate152's Avatar
    Feb 2013
    308
    16,353
    I would recommend overclocking manually rather than using the auto OC as it will likely overvolt your cpu.
    First things first, let's try and get your ram to 3200MHz. We'll set your ram manually rather than using X.M.P.
    1) Go into the bios and hit F5 to reset to defaults and set the AI Overclock Tuner to Manual.
    2) Scroll down to Dram Frequency and select 3200MHz.
    3) Scroll down to Dram voltage and enter in 1.35v
    4) Scroll down to CPU VCCIO voltage and enter in 1.20v
    5) Scroll down to CPU System Agent voltage and enter in 1.20v
    Then click "Dram Timing Control" and enter the primary timings at the very top:
    16
    18
    36
    Command rate 2
    Then hit F10 and Enter to save and exit, let me know if you're able to boot to windows or if you get an overclocking failed message.
    danegeld PC Specs
    Processor7700k
    Casecorsair 900d
    Keyboard microsoft
    Mouse M570
    OS Win 10 pro
    danegeld's Avatar
    May 2017
    24
    ok give me a moment to do that
    Nate152 PC Specs
    MonitorHP ZR30w
    Mouse Logitech G500
    Nate152's Avatar
    Feb 2013
    308
    16,353
    Sure no hurry and good luck.
  7. #7
    danegeld PC Specs
    Processor7700k
    Casecorsair 900d
    Keyboard microsoft
    Mouse M570
    OS Win 10 pro
    danegeld's Avatar
    May 2017
    24
    calle corona
    when i attempt to change the value...when i hit enter it auto populates back to (auto) i need to do something so i can make changes
  8. #8
    Nate152 PC Specs
    MonitorHP ZR30w
    Mouse Logitech G500
    Nate152's Avatar
    Feb 2013
    308
    16,353
    Set the AI Overclock Tuner to Manual, then follow the steps.
  9. #9
    danegeld PC Specs
    Processor7700k
    Casecorsair 900d
    Keyboard microsoft
    Mouse M570
    OS Win 10 pro
    danegeld's Avatar
    May 2017
    24
    im still not sure i have done this correctly although i think i followed your instructions, am i missing something?
  10. #10
    Nate152 PC Specs
    MonitorHP ZR30w
    Mouse Logitech G500
    Nate152's Avatar
    Feb 2013
    308
    16,353
    Open cpu-z, click the memory tab and take a screenshot and post it for me.
