Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 33
    ROG Enthusiast Array
    Mar 2015
    67
    asus poseidon GTX 1080 Ti Water-cooled 65 degrees with fans on
    Dear medeforum lovers.
    I have been in possession of the asus poseidon GTX 1080Ti for a couple of weeks. The video card is water-cooled naturally: D The card will be max 65 degrees only the fans will also turn around. This does not seem to me if the video card is water-cooled seems to me. Is this normal or I have a broken card?
    Mar 2015
    67
    Are there more people who suffer from this? And whether this is normal?
    New ROGer Array
    Sep 2017
    5
    you are not alone. The same problem, only the temperature under 70. but, put the system unit on its side - the temperature dropped to 53 immediately
    Mar 2015
    67
    Quote Originally Posted by garry81 View Post
    That you also have this problem is this a reason for rma? or is it normal?
    New ROGer Array
    Sep 2017
    5
    request to tech support wrote, keep silent for now
    Mar 2015
    67
    Dear Garry
    I will certainly do this for sure. Will I mention what has been said here? Because you also have this problem?
  7. #7
    New ROGer Array
    Sep 2017
    5
    Quote Originally Posted by marcelmaria View Post
    Dear Garry
    of course. why not?
  8. #8
    ASUS HQ Service Rep Array Bill@ASUS's Avatar
    Dec 2015
    433
    Hello marcelmaria
    According to your description, do you mean that the fan will only start to spin if GPU temperature is above 65 degrees? Does it keeps spinning if the temp has dropped under 65 degrees? Any custom setup that you have applied to your card? Or is this all default settings? Thank you
  9. #9
    New ROGer Array
    Sep 2017
    5
    Quote Originally Posted by Bill@ASUS View Post
    Hello marcelmaria
    The question is not on the topic of the work of fans, but on the topic "under water cooling the card heats up to 65 degrees"
  10. #10
    Mar 2015
    67
    Hello marcelmaria
    The question is whether it's normal for fans to turn at 65 degrees on the video card watercooled. As Garry81 stated above.
