Results 1 to 3 of 3
    New ROGer Array
    Jul 2014
    14
    Any G701vik owners around? Questions about fan
    Hello guys,
    I am about to buy this laptop as a second hand since I found a nice deal.
    Fan noise is very critical for me so I would like to ask if an owner can share a video or experiences with standard load fan noise and extreme mod fan noise?
    Am I also able to tweak the fan speed since I do play old games sometimes which doesn't require that much power.
    Thanks for your help
    ROG Guru: Gold Belt Array Clintlgm PC Specs
    Clintlgm PC Specs
    Laptop (Model)Asus G752VY DH72
    MotherboardAsus Z97 Pro WiFi and /Z97 Pro A
    ProcessorI7 4790K
    Storage #1512 GB M.2 Samsung 960 Pro
    Storage #21 TB Samsun 850 Pro
    CaseCool Master Haf
    OS Win 8.1 Pro and Win 10 Pro
    Clintlgm's Avatar
    Jul 2012
    105
    4,123
    Yes generally speaking Asus G series notebooks are very quite. I haven't seen a G701 so I can't say for sure
    Asus does not supply any fan control program.
    Fan control is from the BIOS and is controlled by CPU and GPU temps, if you not stressing the GPU the fan will idle.
    Again not sure about the G701 but all the other G series have fan for each CPU and GPU each have there own fan and fan control profile.
    Also note that G GL GX are 3 different notebooks they are not all the same.
    G752VY-DH72 Win 10 Pro
    980m GTX 4 GB
    32GB DDR 4 Standard RAM
    Z97 PRO WiFi I7 4790K
    Windows 10 Pro
    Z97 -A
    Windows 10 Pro
    New ROGer Array
    Jul 2014
    14
    Quote Originally Posted by Clintlgm View Post
    I have used G750jz and G751jy and very happy with the experience. I heard that G752vs is also silent but quite the opposite with G701vik. For this I would like to hear from an end user how is the experience and would be nice hear it with a video.*
