Results 1 to 3 of 3
    ROG Guru: Brown Belt Array Darnassus PC Specs
    Darnassus PC Specs
    Laptop (Model)G752VS -=-=- G750JX
    MotherboardASUSTeK COMPUTER INC. G752VS (U3E1) -=-=- ASUSTeK COMPUTER INC. G750JX (SOCKET 0)
    Processori7 6700HQ @ 2.60GHz -=-=- i7-4700HQ CPU @ 2.40GHz - 3.40GHz
    Memory (part number)2x16gb (M471A2K43BB1-CRC) -=-=- 2x8gb (HMT41GS6AFR8A-PB)
    Graphics Card #1GTX 1070 (8GB) -=-=- GTX 770M (3GB)
    Sound CardRealtek High Definition Audio / NVIDIA High Definition Audio
    MonitorGSync IPS 75HZ -=-=- Chi Mei 60Hz (Overclocked to 85Hz)
    Storage #1Samsung SSD 960 EVO 250GB x2 -=-=- LITEONIT LCS-256M6S
    Storage #2HGST HTS721010A9E630 -=-=- ST1000LM024 HN-M101MBB
    CPU CoolerStock -=-=- Stock
    CaseStock -=-=- Stock
    Power SupplyStock -=-=- Stock
    Keyboard Stock -=-=- Stock
    Mouse Razer Naga Epic 1st Generation
    Headset SPH 2500
    Mouse Pad Razer Goliathus
    OS Winblows 10 Pro -=-=- Winblows 8.1 Pro
    Network RouterCG3000v2
    Darnassus's Avatar
    Dec 2013
    61
    1,644
    G752VS Sound snap external
    So we all know the internal speakers make a snap every time sound is played prior and after, a crackle, or a pop.. an audible sound when the speaker turns on from its sleeping state, then turns off.
    SO, the same thing is now happening with my EXTERNAL speakers..
    Why in the world is this happening.. and how do we fix it..
    My external speakers make the subtle hiss sound between pops (when audio is awake) like the internal speakers do, as if it's the Audio Driver itself.
    Gosh Blue Lady.. ❤
    JOIN THE ASUS T-SHOOT DISCORD <-- Clicky!
    ROG Guru: Yellow Belt Array
    Apr 2016
    218
    Because Asus either don't care about fixing it, or they can't fix it. Honestly, with the amount of owners on here complaining about this issue, you'd expect Asus would address it.
    Sent from my Nexus 6 using Tapatalk
    ROG Enthusiast Array
    Aug 2017
    19
    71
    It likely is controlled by the audio driver, but it's really just a crappy amp circuit that makes audible transient signals as it powers down. Since it is configured to power down the amp about 2 seconds after the sound drops out we get to hear the transient sounds frequently. This is just bad software and/or hardware design. They go to the trouble of putting in a separate woofer and leave this crappy transient in? It just doesn't make sense.
    Something you could do is either use the spdif output or just stop using the internal amp at all and switch to a USB audio adapter.
