Results 1 to 7 of 7
Thread: NH-D15 Second Fan
09-17-2017 05:39 PM #1
Flink488 PC Specs Motherboard Crosshair VI Hero Processor Ryzen 7 1700x Graphics Card #1 Msi 1070 Gaming X CPU Cooler Noctua NH-D15 Case Phanteks Evolv ATX Power Supply EVGA Supernova G3 750W OS Windows 10
- Join Date
- Sep 2017
- Reputation
- 10
- Posts
- 12
NH-D15 Second Fan
Hi there.bought this mobo last monday,Imounted a NH-D15 on it,but only with one fan,now I think I'll put the second one too but idk where to attach it in the mobo
As seen on the page 16/100 here in the point 5 there are 3 attach for the fans,I attached in the first one from left the case fan connector,in the second one I attached the main fan in the NH-D15,do I attach the second one in the third slot?
I noticed that ''maybe'' the first attachment is for the 2nd fan of the NH-D15,but if I attach the 2nd fan there,where do I attach the Case's fan?In the third one(which is probably for pumps)
09-17-2017 06:59 PM #2
andyliu PC Specs Motherboard Crosshair VII Hero Processor AMD Ryzen 7 3700X Memory (part number) (32GB) 2*F4-3200C14D-16GFX Graphics Card #1 EVGA 980 FTW Storage #1 Samsung Evo 850 500GB Storage #2 Mushkin Enhanced ECO3 480GB CPU Cooler Corsair H105 Case Cooler Master H500M Power Supply Thermaltake TOUGHPOWER 750W Keyboard Logitech G910 Mouse Logitech G502 OS Windows 10 Pro Network Router ASUS RT-AC3100 + PCE-AC88
- Join Date
- Apr 2017
- Reputation
- 14
- Posts
- 169
the header @ top right corner is for the CPU, and they CPU_OPT CPU_FAN AIO_PUMP from left to right.
if I am reading it correctly, you are connecting a case fan on CPU_OPT.
there are multiple location for item no 5 (headers),
hopefully the image helps you plan out where you wanna connect the fan
and if you wanna sync the CPU fan, I will suggest that you connect the fan on CPU_FAN and CPU_OPTLast edited by andyliu; 09-17-2017 at 07:03 PM.
09-17-2017 08:12 PM #3
- Join Date
- Sep 2017
- Reputation
- 10
- Posts
- 12
09-17-2017 10:55 PM #4
Oggy1985s PC Specs Laptop (Model) Samsung 30u3e-K01HS Motherboard ASUS Crosshair VI Hero (AMD x370) Processor Ryzen 7 1700 Memory (part number) G.Skill Flare X 16GB (F4-3200C14D-16GFX) Graphics Card #1 Asus ROG Strix 1080 Ti Monitor LG34UC79G-B & LG 27EA63V Storage #1 Samsung EVO 840, 250 GB & Samsung EVO 850, 500 GB Storage #2 WD 1TB & WD 1TB CPU Cooler Noctua NH-D15 SE-AM4 Case Fractal Design Define S Power Supply EVGA Supernova G3, 750W Keyboard Logitech G810 Mouse Logitech G602 Headset Logitech G430 Mouse Pad Logitech G Headset/Speakers Genius: SP-HF1800A OS Windows 10 Network Router ASUS RT-AC56U Accessory #1 Noctua NF-A14 PWM x4 Accessory #2 Thrustmaster T160000M
- Join Date
- Sep 2017
- Reputation
- 10
- Posts
- 7
For case fans use connectors marked as CHA_FAN1, 2 and 3. If this isn't enough use the water pump connectors though I think that water pump connectors can't be regulated via motherboards fan control software (they work at 100% load).
09-17-2017 11:34 PM #5
- Join Date
- Sep 2017
- Reputation
- 10
- Posts
- 12
09-18-2017 08:02 AM #6
- Join Date
- Sep 2017
- Reputation
- 10
- Posts
- 7
Yes, connecting the whole connector to the CHA_FAN2 will still be controlled by the motherboard.
Motherboard won't know how many fans you connected to the single connector. The downside of this approach is that you can't control the fans individually and if you connect too many fans on the same connector their performance might be hindered because they might require more power than a single fan connector will provide.
Check out page "1-24" of the ASUS Crosshair VI Hero manual. There you can find the table which lists maximum current and power values for each fan header. For power requirement of your fans consult manufacturer's web page. Ie. Noctua NF-A14 PWM uses 0,13A and 1,56W so in theory one could connect 7 fans to the same connector without reducing their performance.
09-18-2017 11:42 AM #7
- Join Date
- Apr 2017
- Reputation
- 14
- Posts
- 169
you use phantek evolve, the fan header are jointed on the back of the motherboard tray, and you can easily unplug and split them.
you dont necessary need to add all fan on the hub as you have enough fan header.
you have 1 rear and 2 front
What I will do is put the rear fan on CHA_FAN1, and 2 front fan can be easily link and add with CHA_FAN2
some ppl been experiencing FAN stuck @ full speed, and it seems the best solution is not overload the I/O chip controller.
so def not going to over stress the fan header.Last edited by andyliu; 09-18-2017 at 11:45 AM.
