Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    ROG Member Array
    Jul 2016
    6
    6700k High Stock Temps
    My specs are as follows:
    Maximus 8 Hero (Non Alpha)
    i7 6700k @ stock
    Radeon R9 295X2
    16 GB 2400 MHZ Corsair Dominator Platinum DDR4
    Seasonic 850w Focus + Gold PSU
    Corsair H80i V2
    Temps are very high for medium gaming, I am afraid to see what they would do in something like Prime95.
    Here's an HWINFO64 screenshot...
    As you can see by the max temps I am getting ~85C at stock. No overclock of any kind.
    I have tried putting LLC to 5, I have set vcore manually to 1.28. I have reseated the cooler and reapplied thermal paste (Noctua NH-1)
    Got any ideas?
    Nate152 PC Specs
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba OCZ VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Mouse Razer Basilisk
    OS Windows 10 Home 64 bit
    Nate152's Avatar
    Feb 2013
    308
    16,357
    Hi Culbrelai
    Welcome to the ROG forum !
    In HWinfo, what is the Maximum Vcore showing ?
    ROG Member Array
    Jul 2016
    6
    Max Vcore is 1.296ish, according to HWINFO, I manually set it to 1.28 in the BIOS.
    BIOS is also up to date.
    My case is a Cooler Master Cosmos II with at least 14 fans total, with the CPU rad venting out of the top and the GPU rad out of the back. I might try swapping them...
    Most of the fans are high performance Yate Loons/Scythe Slipstreams...
    Room temperature is 70-75F.
    ROG Guru: Green Belt Array panzlock PC Specs
    panzlock PC Specs
    Laptop (Model)ASUS X553M, ASUS Zenpad 10 Z300M, ASUS X542BA-DH99
    MotherboardASUS P8Z68-V LX, ASUS Z170-A, ASUS ROG Strix B350-F Gaming
    ProcessorIntel i5-2500K, Intel i7-6700K, AMD Ryzen R7 1700
    Memory (part number)8GB Kingston 1333MhzDDR3 C9, 16GB G.Skill Aegis 3000Mhz DDR4 C16, 16GB G.Skill Trident Z 3200Mhz C16
    Graphics Card #1EVGA GTX 560Ti, ASUS ROG Strix GeForce GTX 1070 O8G OC, Sapphire Nitro+ RX Vega 56
    Monitor32" INSIGNIA 720p, 32" Samsung 1080p C32F391FWN, 32" ASUS 1440p VA32AQ
    Storage #1Seagate 150GB 7200RPM, Samsung 850 EVO 250GB 2.5" 6Gb/s Solid State Drive (X2)
    Storage #2Seagate 500GB 7200RPM, WD Blue 3TB - 5400 RPM SATA 6 Gb/s 64MB Cache 3.5 Inch
    CPU CoolerDeepcool GAMMAXX 300, Deepcool Lucifer V2, Wraith Spire
    CaseAntec Sonata, Deepcool Dukase V1, Deepcool Dukase V3
    Power SupplyATX 650, EVGA SuperNOVA 850 P2 (X2)
    Keyboard Logitech K220, MSI Interceptor DS4200 (X2)
    Mouse Microsoft 1850, Microsoft 4500, Gamdias Erebos LE, MSI DS 100, Redragon M601 Centrophorus
    Headset/Speakers Logitech Z313, Logitech Z506 (X2)
    OS Windows 10 Home X64, Windows 10 Pro X64 (X2)
    panzlock's Avatar
    Nov 2016
    54
    701
    I personally never like that many fans in a case because it's difficult to determine where that air is actually going, and how much of it is trapped and recycled inside that case.
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,357
    Try setting the Vcore to 1.15v - 1.20v.
    ROG Member Array
    Jul 2016
    6
    Hotel Avenue
    Quote Originally Posted by Nate152 View Post
    Alright now under the same conditions max temps go to 70-75c, still kind of high for a good liquid cooler with a thick rad like the h80i v2.
    I set VCore to 1.175 and now it maxes according to HWINFO at 1.184. Humm... Might move rads around...
  7. #7
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,357
    That's looking better !
    When you installed the H80i did you use the pre-applied thermal compound on the waterblock or did you use your own? If you used your own did you remove the pre-applied thermal compound ? Also make sure the waterblock is making good contact with the cpu, not super tight just snug. Make sure the pump is running at 100% too.
    I'd remove the stock thermal compound and use Thermal Grizzly Kryonaut, this should help lower temps a little more.
    http://www.thermal-grizzly.com/en/pr...16-kryonaut-en
  8. #8
    New ROGer Array
    Sep 2017
    7
    I would check the mounting and thermal paste.
    Even when mine is hitting 1.4V under load it doesn't go higher as about 80°C on Prime!
    Gaming is 60° max when the Water got warm. (And thats all on very low Fanspeeds).
    But i use a custom loop with 280mm Radiator (thin one)
    Oh, i forgot. Mine is delidded and the Factory paste is exchanged. Might also be a factor.
  9. #9
    ROG Guru: White Belt Array aceisme PC Specs
    aceisme PC Specs
    MotherboardASUS Maximus VIII Hero
    Processori7-6700K
    Memory (part number)G.Skill Trident Z F4-3200C16D-16GTZB 16GB
    Graphics Card #1EVGA GTX 980TI Classified
    Sound CardOn board sound
    MonitorASUS ROG Swift PG278Q
    Storage #1Samsung 950 Pro Series 512GB M.2 SSD
    Storage #2Intel SSD 540s - 240GB - SSDSC2CW240A3
    CPU CoolerCorsair H115i
    CaseCorsair Obsedian 450D
    Power SupplyCorsair H850i
    Keyboard Logitech G910
    Mouse Logitech G502
    OS WIN10 Enteprise
    Nov 2015
    32
    75
    Swapping rads around will not fix your problem. Something must be wrong there. Either the cooler/paste is not on properly or the water pump is not working. Or maybe the cooler has air bubbles inside? Although you should be able to hear a bubbly noise from the water pump if that was the case. Silly question, but did you connect the pump to a voltage source?
    My 6700k barely reaches 60C under 100% load with a H110i rad. Temps usually settle around mid to high 50s under full load. CPU is running at 4.6GHz, LLC-6 with Cache at 4.5GHz and 3466MHz on mem. Voltage shown in HWINFO is 1.249v. I can't remember the exact setting I have in the BIOS but it's around 1.235v.
  10. #10
    panzlock PC Specs
    panzlock's Avatar
    Nov 2016
    54
    701
    My 6700K under load was 55C-60C with a Lucifer V2 air cooler. Based on your temps it seems your cooler might be the issue, here. As pointed out above it would be a good idea to reapply thermal paste (don't cheap out, get a good one) and re-seat your cooler.
    Couple of other things, though. What are your ambient temps? And are your CPU temperatures constant? I noticed that my 6700K had severe voltage and temperature spikes that would reach 75C-80C before I changed some BIOS settings.
    Just to clear up one last thing, you mention the H80i as your cooler, but you swapped that for a Noctua NH-1 to check? Is that correct?
