R5E10 SupremeFX Hi-Fi Front panel doesnt work correctly
berkkocaturk
front panel was not working with my sound player when i switched to it while player was open it worked but if i close and open again it did not work at all (tested with kmplayer and media player classic) so i said lets update it and installed latest
SupremeFXHiFi_V1.9.114.26_6.0.6001.0_20170814_WHQL
V7904_20160815_WHQL_DTS_StudioSound_SonicSuite_2.2.28_SonicRadar_2.1.3401.0
and now it doesnt work at all!
i turn the knob but sound doesnt get loud it stays at 0 you can see it on video
https://youtu.be/qb5JMGucjfg
4 REPLIES 4
Chino
Level 15
Chino wrote:
Did you uninstall the previous version or did you install the update over it?
i uninstalled first restarted than installed new
I did everything audio driver supremefx software and firmware update and it now works as it should but still not being able to use sonicstudio on front panel is just terrible because front panel audio is weak in bass my headphones can handle a lot but there is no equalizer option
Good luck brotha. I've been fighting with this issue for ages. Asus simply doesn't care. This will definitely be my last ASUS motherboard.
