Page 5 of 5 FirstFirst ... 3 4 5
Results 41 to 49 of 49
  1. #41
    ROG Guru: Yellow Belt Array
    May 2017
    32
    165
    Quote Originally Posted by gupsterg View Post
    Threadripper does not have "onboard video" ....
    Oops sorry about that, you're right! ahahaha I remember an asus rep telling me there was an on board video for the x399 when I had issues with my DP ports. I spent 5 minutes looking for it and couldn't find it and he insisted it was there and that I should look again before the next trouble shooting step.
  2. #42
    ROG Member Array
    Oct 2013
    19
    I’m going to go exchange the board today. My concern is what’s the cause of this if I get another board hook it back up and the same thing happens I’d be on the verge of insanity. So any ideas fellas what would cause this? Bad cpu? I tested the power supply it came on powered the fans and water pump just fine. Idk what else it could be.
  3. #43
    May 2017
    32
    165
    Quote Originally Posted by Strykewave View Post
    Since your mobo isn't starting up here's a list of what it can possibly be :
    1) Bad power supply - but you said your power supply works and it's very rare for a power supply to not work any how
    2) bad motherboard - might just be a bad motherboard since it's not outputting what ever power is being signaled to it
    3) bad connections - maybe bad connection with the wires from case wires to mobo, or bad connection from power supply to mobo or bad connection from power supply to case wires
    I don't think it's a bad cpu because even in the rare chance that the cpu is bad the mobo would have started up. Be prepared to wait 20 days + for your repair mobo to come back.
  4. #44
    ROG Guru: Yellow Belt Array Cory29 PC Specs
    Cory29 PC Specs
    MotherboardROG Zenith extreme x399
    Processor1950x
    Memory (part number)G Skill F4-3200C16-8GTZ - 64gb
    Graphics Card #1GIGABYTE GeForce GTX 980 Ti WF
    Monitorcintiq 22hd touch
    Storage #1Sam SSD 850 EVO 1TB
    CPU Coolerxspc block - D5 - 3x120 slim rad
    CaseView 71 (doesn't fit board)
    Power SupplyEVGA supernova 1000G3
    Keyboard K95
    Aug 2017
    131
    There is a Bug after 804 that was introduced
    If a storage device is plugged into the back I/O ports then the data can not be read even through uefi flashback tool
    If the tool is tried to be used the board will brick and only turning the power on and off (unplugged) for 5 min+ will correct the issue
    Its basically caused by unclean programming of the UEFI -- after garbage collect I was able to install the new uefi but the USB storage bug still remains
    don't know if you have a variant of this bug -- but after I have found the board power button not responding unplugging for 5 min corrects the problem
    (not everyone experiences this bug)
  5. #45
    ROG Member Array
    Oct 2013
    19
    Microcenter swaps the board out the same day and handles the rma on there end . I left it with the tech there it’s gone over my head and I can’t keep throwing money at it. Thanks for the help I will post wha happened for future reference. Thanks guys.
  6. #46
    ROG Guru: Blue Belt Array gupsterg PC Specs
    gupsterg PC Specs
    MotherboardAsus Maximus VII Ranger
    Processori5 4690K
    Memory (part number)HyperX Savage 2400MHz 16GB
    Graphics Card #1Sapphire R9 Fury X (1145/545 Custom ROM)
    MonitorAsus MG279Q
    Storage #1Samsung 840 Evo 250GB
    Storage #2HGST 2TB
    CPU CoolerThermalRight Archon SB-E X2
    CaseSilverstone Temjin 06
    Power SupplyCooler Master V850
    Headset/Speakers HyperX Cloud
    OS Win 7 Pro x64 / Win 10 Pro x64
    gupsterg's Avatar
    Feb 2015
    99
    931
    I think this is best course of action.
    Quote Originally Posted by Cory29 View Post
    Going by the OCN bug thread there doesn't seem to be many that have that bug.
    I've had my board since launch, I have used many UEFIs and always use flashback.
    21/02/18 sitting on UEFI 0019
    Attachment 72045
    Later on on the day UEFI 0902
    Attachment 72046
    Following day I'm on UEFI 0901
    Attachment 72047
    Intel Defector AMD Rebel
    TR 1950X - Custom WC - Asus Zenith Extreme Alpha - G.Skill Trident Z 3400MHz C14 QC - RX VEGA 64
    R5 3600 - Custom WC - Asus Crosshair VII Hero Wifi - G.Skill Ripjaws V 3800MHz C16 - Sapphire HD 5850 Toxic
    24/7 OC: i5 4690K @ 4.9GHz CPU@1.255v 4.4GHz Cache@1.10v - Archon SB-E X2 - Asus Maximus VII Ranger
    Sapphire Fury X (1145/545 ~17.7K GS 3DM FS)
  7. #47
    ROG Member Array
    Oct 2013
    19
    Defective 24 pin connection from manufacturer.
  8. #48
    gupsterg PC Specs
    Processori5 4690K
    MonitorAsus MG279Q
    Storage #2HGST 2TB
    gupsterg's Avatar
    Feb 2015
    99
    931
    PSU or mobo?
    Rereading past posts implies you had issues with the various combos of HW at your disposal.
    Any update on this? I’m having the same issue. Originally had 1500watt thermaltake toughpower psu on ASRock Taichi board. Computer worked for a month then stopped thought power supply died replaced with seasonic 1300watt prime *still just board d lighting up. Replaced mobo to ASUS Rog zenith X399 after the everything was put back together only the leds on the board would light up power button on the board does nothing please help I’m running out of ideas as to why this thing won’t even turn on .
    This computer worked with Taichi motherboard 1500 watt toughpower was going to reinstall windows and in the middle of getting this pc ready it went off and only the lights on the Taichi board would light up the sand as the new ASUS zenith. I tested the psu and the fan did not come in so I purchased a seasonic 1300 watt prime hoping that was the issue. Nothing. So I’m stuck with just the lights on the board lighting up. The ryzen cpu was set to game mode when was doing the windows refresh. The reason I was reinstalling windows because I felt the comp was running slow and hitchy so I wanted to reinstall to see if it helps bring back the swiftness of this machine.
  9. #49
    May 2017
    32
    165
    wow thanks for the update and glad you figured it out.
