Results 1 to 4 of 4
    ROG Member Array
    Jan 2017
    17
    G752VM Wifi does not stay connected since Creators Update
    When booting the machine to the Win10 login screen, my wifi briefly connects and then disconnects. I can continue to log in and then have to select my wifi router again to connect. The checkmark for "Connect Automatically" is checked BTW. Or I can cycle the airplane mode off and on (FN+F2) from the login screen and it connects and stays connected. I have installed the ASUS update from the LAN_Realtek_Win10_64_VER1037232015 folder. This is just since installing the Creators Update. Anyone else notice this?
    ROG Member Array
    Jan 2017
    17
    Hmm, lots of views but no comiserators. Well, let me update then. I tried several things attempting to narrow down where the problem was. Whatever I tried would work for 3-4 days and then the problem would return. And I think I tried just about everything available in Windows 10 Home. The Pro version might have more to fiddle with. Last resort was the master reset available in Windows Settings>Network & Internet>Status and Network Reset at the bottom of the list. It says that it removes and replaces all the various comm bits involved and requires you at the end to log back in to your wifi router. Six days now with no problem. If that changes, I'll be working on it again.
    ROG Guru: Gold Belt Array Clintlgm PC Specs
    Clintlgm PC Specs
    Laptop (Model)Asus G752VY DH72
    MotherboardAsus Z97 Pro WiFi and /Z97 Pro A
    ProcessorI7 4790K
    Storage #1512 GB M.2 Samsung 960 Pro
    Storage #21 TB Samsun 850 Pro
    CaseCool Master Haf
    OS Win 8.1 Pro and Win 10 Pro
    Clintlgm's Avatar
    Jul 2012
    99
    4,104
    Uninstall you driver and software for WiFI reboot and reinstall driver from Asus Support or your eSupport folder.
    What has happen is Windows installed it own native driver for your Wi Fi, and your notebooks doesn't like that one.
    Check your other hardware drivers update them from either your eSupport folder of Asus Support. then block Windows Update from updating drivers.
    You can also use show/hide tool from Microsoft to hide particular updates and prevent them from running and installing
    G752VY-DH72 Win 10 Pro
    980m GTX 4 GB
    32GB DDR 4 Standard RAM
    Z97 PRO WiFi I7 4790K
    Windows 10 Pro
    Z97 -A
    Windows 10 Pro
    Banned Array JustinThyme PC Specs
    Laptop (Model)G752VY-DH72
    MotherboardRampage VI Extreme
    ProcessorI9 9940X
    Memory (part number)64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17
    Graphics Card #1ASUS Strix 2080Ti O11G @ 2.1GHz
    Graphics Card #2ASUS Strix 2080Ti O11G @ 2.1Ghz
    Graphics Card #3ROG Nvlink
    Graphics Card #4Have to feed animals
    Sound CardExternal Audioengine D1 24 bit 192kbps DAC
    MonitorASUS PG348Q @ 100Hz
    Storage #1Intel 905P 480GB U2 flavor
    Storage #2Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1
    CPU CoolerHeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS
    CasePhanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM
    Power SupplyCorsair AX 1500i
    Keyboard ASUS Claymore
    Mouse ASUS Spatha, Logitech MX Master
    Headset Sennheiser HD 700
    Mouse Pad ASUS ROG Sheath
    Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub
    OS Win10 Pro 1809
    Network RouterNetGear NightHawk X10
    Accessory #1 NetGear Prosafe 10GBe Switch
    Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
    Nov 2013
    144
    3,858
    The LAN Realtek is not the wireless.*
    I’m pretty certain that machine is running the intel AC 8260 or 7260. Both use the same drivers. What’s on the ASUS website is old and outdated. For outsourced hardware it’s best to get it from the vendor*
    Intel download
    **https://downloadcenter.intel.com/dow...Windows-10?v=t
    Open control panel, locate the WiFi adapter. Right click and uninstall
    Install the pro set package I linked above, download it before you start this.
    When install is finished reboot.
    Go back into device manager and make sure the driver version is the correct one.**
