Results 1 to 3 of 3
    ROG Guru: White Belt Array Moloch's Avatar
    May 2012
    91
    Question about AVX instruction overclocking
    So the default for "AVX Instruction Negative Offset" on my R6A was 2. This works fine until I get my cores up to 4.8GHz. With 4 cores at 4.8 I can run Aida64 stability test for over an hour without error.
    Then I tried using the RoG RealBench, and with even a single core at 4.8 it crashes on the second test, H.264 Video Encoding, around 3-7% completion. I tried adjusting most of my voltages up 100mv or more, I even bumped my core voltage to the 4.8 core from 1.225 to 1.3, and it still crashes at the same place.
    Eventually I dropped the AVX negative offset from 2 to 3, and the test passes now...
    Is there any way to get this running with 2 offset, or is 3+ typical at 4.8GHz+ OC?
    Is there any specific voltage I should try adjusting?
    Edit: With further testing using my best core I was able to pass this test at 4.8GHz with -3 offset and only 1.19v, and 4.9GHz with -4 offset on 1.26v... but this slows down the AVX instruction on my 4.5GHz cores to 4.1GHz
    Is there a way to set this on a per-core basis? Can I put my 4.8/4.9 cores at -3/-4 and my 4.5 cores at -1/-2?
    Tech Marketing Manager HQ Array Raja@ASUS's Avatar
    Apr 2011
    161
    7,454
    AVX instruction sets require more Vcore than non-AVX workloads. Not much you can adjust outside Vcore. If you use per core rules, you're also affecting your non-AVX frequency for multi-threaded workloads. 4.5G for AVX workloads isn't bad at all.
    Banned Array JustinThyme PC Specs
    Laptop (Model)G752VY-DH72
    MotherboardRampage VI Extreme
    ProcessorI9 9940X
    Memory (part number)64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17
    Graphics Card #1ASUS Strix 2080Ti O11G @ 2.1GHz
    Graphics Card #2ASUS Strix 2080Ti O11G @ 2.1Ghz
    Graphics Card #3ROG Nvlink
    Graphics Card #4Have to feed animals
    Sound CardExternal Audioengine D1 24 bit 192kbps DAC
    MonitorASUS PG348Q @ 100Hz
    Storage #1Intel 905P 480GB U2 flavor
    Storage #2Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1
    CPU CoolerHeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS
    CasePhanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM
    Power SupplyCorsair AX 1500i
    Keyboard ASUS Claymore
    Mouse ASUS Spatha, Logitech MX Master
    Headset Sennheiser HD 700
    Mouse Pad ASUS ROG Sheath
    Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub
    OS Win10 Pro 1809
    Network RouterNetGear NightHawk X10
    Accessory #1 NetGear Prosafe 10GBe Switch
    Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
    Nov 2013
    144
    3,858
    AVX workloads put a hurting on the power draw and as such puts the flame on the heat.*
    Silicon lottery has in the setting for their OC to be stable
    *-3 AVX Offset
    *-5 AVX512 Offset
