Page 15 of 15 FirstFirst ... 5 13 14 15
Results 141 to 149 of 149
  1. #141
    ROG Guru: Yellow Belt Array MirceaForce PC Specs
    MotherboardASUS RAMPAGE VI EXTREME
    ProcessorIntel® Core i9-7920X Processor Extreme Edition 4.2 GHZ auto
    Memory (part number)G.SKILL 32GB 14-14-14-34 [Trident Z RGB] F4-3200C14Q-32GTZR
    Graphics Card #1NVIDIA GEFORCE GTX 1070 Founders Edition
    Graphics Card #2Samsung SSD 850 EVO 2TB
    Graphics Card #3Samsung SSD 850 PRO 2TB
    Sound CardSound Blaster Z
    MonitorIPS LED LG 27" 27UD69P 27 inch 4K 5 ms WhiteFreeSync - disabled, Display port
    Storage #1Samsung 950 PRO M.2 512GB OS
    Storage #2Samsung SSD 850 EVO 2TB
    CPU CoolerCORSAIR Hydro Series H80i v2
    CaseCooler Master: HAF X
    Power SupplySeasonic PRIME Titanium 850w
    Keyboard normal usb benq
    Mouse Razer Taipan
    Headset/Speakers Logitech Z-5500 digital
    OS Windows 10 x64 Pro up to date
    Network Router:Intel® Ethernet Server Adapter I210
    Accessory #1 LG OLED55C7V
    MirceaForce's Avatar
    Oct 2016
    6
    139
    I have installed this new motherboard with the dimm.2 on slor 2.2 my samsung 950 pro 512gb and I cannot find it in bios in boot devices ...i'm running the latest bios ...the dimm card is inserted corectlly i have the red led on the dimm card ...is this normal to not work in this slot ? ??
    please help me
  2. #142
    New ROGer Array fexnok PC Specs
    fexnok PC Specs
    MotherboardRampage Extreme Vi
    Processori9 7980XE
    Memory (part number)CMK64GX4M8B3400C16
    Graphics Card #1NVIDIA GTX 1080Ti Founders
    Sound CardRME Fireface UFX+
    MonitorASUS PG348Q
    Storage #1Samsung 960 PRO 2TB x 2 + Intel 750 1.2TB
    Storage #2Samsung SM961 Polaris 1TB x 2
    CPU CoolerNoctua NH-D15S
    CaseCalyos NSG S0 Fanless (soon)
    Power SupplySeasonic Prime 850 Titanium
    Keyboard Code V2B
    Mouse Logitech M330
    Headset Sennheiser HD800
    Mouse Pad Black one
    Headset/Speakers Yamaha MSP7
    OS Windows 10 Pro
    Network RouterWatchguard T50-W
    Accessory #1 Sennheiser HDVD800
    Accessory #2 QNAP TVS-882ST3
    Accessory #3 ASUS M.2 Hyper X16
    Oct 2016
    46
    Quote Originally Posted by MirceaForce View Post
    please help me
    Is this a new installation? Have you tried dimm.2 slot 1?
  3. #143
    Mouse Razer Taipan
    Oct 2016
    6
    139
    po
    Quote Originally Posted by fexnok View Post
    yes new installation not i have not tried on that slot 2.1 only on 2.2 slot.....but this is normal or what ?
    shoud i change something in bios ?
    this 950 pro was working on the old sistem asus rampage v extreme
  4. #144
    fexnok PC Specs
    Processori9 7980XE
    MonitorASUS PG348Q
    Keyboard Code V2B
    Mouse Logitech M330
    Mouse Pad Black one
    OS Windows 10 Pro
    Oct 2016
    46
    I don't think so. But just go under Onboard Devices Configuration and change M2_1(DIMM.2) source to CPU (preferably)
    Then Under Boot menu change CSM to disabled and see if it works
  5. #145
    ROG Junior Member Array
    Nov 2014
    2
    RAID between the 2 different DIMM.2 cards on the Apex
    Quote Originally Posted by Moloch View Post
    I was able to set up raid 0 with 2x Samsung 960 on a Dimm.2 with R6A. Unfortunately it appeared that the DIMM.2 slot is connected via a single 4x bus, rather than a 4x bus for each slot. So I still had a max speed of ~3500GB/s.
    After setting up raid between the 2 different DIMM.2 cards on the Apex, I got speeds of nearly double. So I would recommend setting up raid between the single chipset slot and one of the DIMM.2 slots on the R6E, so they each get their own dedicated 4x lane (or get a PCIe card for VROC that supports non-Intel M.2, I think ASUS makes one)
    Keep in mind, there are 2 different types of raid now:
    IRST = VROC raid (must use VROC/cpu lanes... might require Intel brand M.2 drives... should be bootable) (I'm guessing this is the type you tried?)
    RSTe = Chipset raid (I use this type, allows any drive, but not bootable)
    Yes, Apex has one DIMM.2 slot connected to PCH, and another one, connected directly to CPU (I mean VROC), so you mean that you had ONE Samsung 960 in each DIMM.2 and was able to set RAID0 ? ...please, clarify. Many thanks in advance.
  6. #146
    ROG Guru: Brown Belt Array Brighttail PC Specs
    Brighttail PC Specs
    Laptop (Model)Asus G751JT
    MotherboardAsus x299 Rampage VI Extreme
    ProcessorIntel i9-7900x
    Memory (part number)Corsair Dominator Platinum SE 3200Mhz 4x8
    Graphics Card #1MSI GTX 1080TI
    MonitorAcer XB321HK (4k,IPS,G-sync)
    Storage #1Intel 900p (Boot) 2xSM961 (RAID 0) Games
    Storage #2Samsung 850 Pro 512GB - WD Black 4TB
    CPU CoolerCustom Water Cool
    CasePhanteks Enthoo Elite
    Power SupplyCorsair AX 1200i
    Keyboard Corsair Platinum 95
    Mouse Asus SPATHA
    Mouse Pad Corsair MM800
    Headset/Speakers Kanyo Y5
    OS Windows 10 64 bit
    Accessory #1 2 x Alphacool Full Copper Radiator 420mm/280mm
    Accessory #2 Monsoon MMRS reservoir w/ 2 x D5 Vario Pump
    Accessory #3 Monsoon Free Center Compression Fittings
    Sep 2014
    33
    1,331
    Quote Originally Posted by NixNemo View Post
    If he is doing RAID 0 as bootable he is doing it through the PCH bus, which is possible but it will cap seq reads at 3500 ish, just like the z170/z270 boards. VROC RAID 0 on a bootable drive is NOT possible without using specific Intel drives. The CPU DIMM.2 has 8 pci-e lanes attached to it so if you were to set up your Windows OS on the PCH DIMM.2 then you could do a RAID 0 non-bootable drive and get full windows RAID speeds of 6000-7000 Seq Reads.
    Panteks Enthoo Elite / Asus x299 Rampage VI Extreme / Intel I9-7900X / Corsair Dominator Platinum SE 4x8 3200MHz
    MSI GTX 1080 TI / 2x Intel 900p in a bootable VROC RAID 0 / Samsung 960 Pro 512GB
    Samsung 850 PRO 512GB / Western Digital Gold 8TB HD
    Corsair AX 1200i / Corsair Platinum K95 / Asus Spatha
    Acer XB321HK 4k, IPS, G-sync Monitor / Water Cooled / Asus G571JT Laptop
  7. #147
    New ROGer Array
    May 2018
    1
    [QUOTE=JustinThyme;689638]
    Quote Originally Posted by dirray View Post
    Ive had different results. The minute I put either a hyper M2 card in that slot or a 900P intel drive in PCIEX8_4 DIMM.2_2 goes inactive. I repeated this process many times. May be different with a raid controller but when you set the Advanced CPU storage to Hyper M2X16 or PCIEX4 for PCIEX8_4 DIMM.2_2 is inactive. I removed second 1TB 960 pro from DIMM.2_2 because of it.
    Yes you can raid up two M2 drives through the PCH and actually DATA only VROC for a trial version just to see what you cant have and it will expire in 90 days.
    Do you have the Advanced tab, PCH storage set to raid and the aforementioned tabs shown in post above the DIMM.2 set to PCH?
    Hey do you ore someone else know what happend after the 90 days of trial? I Don´t want a bootable RAID. The software RAID0 is enough for me, but i don´t know what happend with it wenn the Trial for the IRSTe is over. can i use it either or will it be deleted/not accessible?
  8. #148
    Brighttail PC Specs
    Mouse Asus SPATHA
    Sep 2014
    33
    1,331
    [QUOTE=Razor93;719217]
    Quote Originally Posted by JustinThyme View Post
    If you aren't using bootable RAID, then you don't need the Enterprise version of RST which runs out in 30 days. Just go to Disk Management and setup your RAID there. You want to use SOFTWARE RAID but not the RST software but WINDOWS software. Windows RAID is better anyway because it is faster than the VROC under the RST software. BTW after 90 days you won't be able to access that drive anyway. My best advice is to copy what you have on your current RAID drive to another drive. Kill the RAID array, uninstall the RST and use Disk Management to recreate the RAID array and copy back your files. GL.
  9. #149
    ROG Enthusiast Array
    Aug 2014
    33
    Hi guys,
    Got a question regarding the dimm m.2 adapter on the Apex IX. Reason you can’t go over 3500mb/s on a raid with two m.2 drives one on each side is because ultimately your either limited to a total x4 bandwidth or limited by the pch. Correct?
    So if I want to have a boot drive on a single M.2 drive on one side and a data drive on the other side you can set that m.2 to cpu pcie operation and as long as they are not bootable have independent 3500mb/s throughput from both sides at same time?
    * Thanks*
