Asus Aura firmware for X370-PRO
Borzywit
Hello,
I am aware of Aura fix provided on this thread https://rog.asus.com/forum/showthread.php?94418-Aura-firmware-reflash-recovery-tool however this firmware enebles mobo lED strip as four seperate strips (Back IO, PCH, Header 1, Header 2). Also my RGB header is dead. Can we have LED firmware bin file designed for X370-PRO motherboard?
5 REPLIES 5
Borzywit
Maybe someone with working X370-PRO aura could write FW and share it? Procedure is similar but command would look like this
aura_update.exe -s "working_x370_aura_fw.bin"
Alexdj2
Borzywit wrote:
Hello,
Did you ever find a solution?
Alexdj2
Got the file from someone on another post. Here it is for anyone with the same issue https://a.uguu.se/Dp6VrOZe73uW_working_x370_aura_fw.zip
the link is broken. please can you send me the file. I really need this 😄
CalcProgrammer1
I bricked my Aura controller reverse engineering it, but luckily I had a memory dump of it from my reverse engineering efforts. From that memory dump I pulled this firmware image, flashed with the Asus tool and it's working fine again!
https://gitlab.com/CalcProgrammer1/OpenAuraSDK/uploads/6e5466d1e50787c09753ecd60a85967f/primex370pro...
