Results 1 to 1 of 1
    New ROGer Array
    Sep 2017
    6
    Thumbs up Problem with Aura and z270-ar
    I built a computer with an Asus Prime z270-ar motherboard and Phanteks led strips in my rig hooked up to the RGB headers.
    When I first booted up the computer, everything ran fine. I installed the latest Aura software and changed the led colors and all. But once I shut the computer down, that was it. Since then, the led strips and the RGB on the motherboard no longer work.
    I've tried reinstalling the Aura software, setting it back to default, uninstalling, turning RGB on and off in the BIOS. I've tried unplugging the PC and leaving it overnight. But nothing.
    This seems to be a very common problem. Is there a fix yet? It's getting a bit ridiculous.
Tags for this Thread
