09-26-2017 06:16 AM - last edited 3 weeks ago by ROGBot
09-26-2017 11:28 AM
09-26-2017 01:25 PM
kkn wrote:
just by pure guess, the 00 mainly means dead bios/cpu
did you instal enny components maby before this happened?
or there can be a loose part/connection on the board ( just guessing on this one!!! ).
i dont know if that board have usb flashback (for a try and reflash 1'st bios ) and see if you can flash bios 1 and see if you can get it to work.
i have not had this board so i would wait until some one else with more experience then me on this board would give bether advice.
09-26-2017 02:06 PM
09-26-2017 03:01 PM
Nate152 wrote:
Hi Brathdari
If copying bios 2 to 1 or flashing bios 1 doesn't work, it would seem you have a faulty bios 1 chip. If it does work then bios 1 was just corrupted.
Keep us updated.
09-26-2017 03:23 PM
09-27-2017 10:51 AM
Nate152 wrote:
Well as you say you're having storms and power outages, this can cause a corrupted a bios. A corrupt OS could keep your pc from booting to windows but it should still start and let you in the bios.
You can replace the bios chip, I'm not sure exactly where it's located on your motherboard but it should be marked, it just pulls out with a special tool then you put the new one in.
Something like this only yours may not have the raised connector, it's not difficult to do. The reason for two bios chips is in case you have problems with one, you have a second as backup and as you can see it's a nice feature.
Start at 2:45
09-29-2017 04:29 AM
09-29-2017 10:11 AM
Brathdari wrote:
Sadly problem reoccurred.....however.
After a frightening dream I had in the wee hrs of the morning I couldn't get back to sleep...so I did some more research.
Came across this "RAMPAGE IV EXTREME - WILL NOT TURN ON" here on ROG forums (up til now I can't believe how I missed this thread) and found an interesting post that can possibly work for ppl experiencing the same exact issue with R4E. Here's the link http://youtu.be/OyNeP8Kkl9s
Workaround is a little wacky but it works!! A blow dryer...I kid you not!!!
I was watching this vid and reading the comments I got all excited and couldn't wait till for the sun to break out and try this thing.
At first, It didn't work when I used my old CMOS Battery , so I took 1 from my Mom's Blood Tester (gotta replace that tho!) fired up the Blow dryer and the Bloody thing work! I can't believe it. I mean, I had already changed my CMOS Battery with a New 1 and I didn't work but somehow the heat from the Dryer jump-started it. That explains why it work as soon as I get to the repair shop, the extreme heat trapped in my car somehow juiced the Mobo/CMOS Battery area.
Problem solved!! But will eventually have to replaced this Mobo as it has a big flaw. I just wanted to be sure It was the mobo and in the end it was.
