Page 1 of 5 1 2 3 ... LastLast
Results 1 to 10 of 44
    ROG Guru: White Belt Array
    May 2017
    96
    Adaptive / Offset mode
    Hi guys, I oc'd my i5-6600k to 4.4 @ 1.2 v, I would to switch to offset / adaptive mode to lower the voltage at idle. When I set offset mode it shows the signum and the offset value only, where do I need to set the base voltage?
    Should I turn off Turbo mode?
    Nate152 PC Specs
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba OCZ VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Mouse Razer Basilisk
    OS Windows 10 Home 64 bit
    Nate152's Avatar
    Feb 2013
    308
    16,373
    Hi amphetamina
    Try using adaptive mode and enter in 1.20v in the "Additional Turbo Mode CPU Core Voltage Override.
    Let's hope this fixes the pausing.
    May 2017
    96
    are these voltages ok? isnt the VCCIO too high?
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,373
    You have to set the CPU Core/Cache voltage to adaptive then it will give you the "Additional Turbo Mode CPU Core Voltage Override". Make sure the windows power plan is set to balanced.
    You're running 16GB of 3200MHz, try both cpu vccio voltage and cpu system agent voltage at 1.15v - 1.20v.
    May 2017
    96
    Is the CPU standby voltage ok?
    Is it better to use offset or adaptive? I've read it's unsafe when running applications that are implemented with AVX instructions.
    Also, when I select the Offset mode, where is the base voltage?
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,373
    Try using adaptive mode.
    I let the cpu stand by voltage on auto and you should be able to get it lower to around 1.15v - 1.20v.
    Is your games still pausing after overclocking your cpu ?
  7. #7
    May 2017
    96
    I leave on auto but it fix there
    yes
  8. #8
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,373
    Try setting the voltages I mentioned, they do look a little high.
  9. #9
    May 2017
    96
    These are the stock voltages
    How much offset voltage for adaptive mode?
  10. #10
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,373
    The voltages now look much better but that will change when you set your ram.
    You won't know what offset voltage to use until you put a load on the cpu, however much it's going over 1.20v is what you'd use as an offset.
    For instance, you have 1.20v set in the bios but under load say it's going to 1.240v, you'd use a negative offset of -0.040v to keep the voltage at 1.20v.
