Gl502vm GPU temperature and memory clock issues
Opreax
This is my normal GPU temperature and memory clock, Memory clock didnt change since I bought laptop (5months) and temeprature during gaming is 95°.
Please fix it, its serious.
https://i.imgur.com/o2xciG1.jpg
5 REPLIES 5
FastM
normal yes,
fixable yes!
take a look around this forum, plenty of threads explaining what to do (undervolting)
undervolting through afterburner didnt work
CPU undervolting using Intel XTU and possibly disabling Intel Turbo boost through the methods described in this forum. Although if they are stock temps at idle you may have a bigger issue.
StarJack
Did you make fix yet???!!
link626
95C is normal.
As long as it doesn't throttle, you're doing ok.
CPU can run 99C all day long, and you're not even there yet.
