Results 1 to 9 of 9
    New ROGer Array erik-pro PC Specs
    erik-pro PC Specs
    Motherboardasus z270 e gaming
    Processori7 7700K
    Graphics Card #1internal
    Sound Cardinternal
    Monitorno
    Storage #11 tb hdd
    Storage #2500gb hdd
    CPU Coolerfractal design Kelvin S36
    Casefractal design Define s
    Power SupplyFractal Design Edison M 750 W
    Headset hyper x cloud core
    OS windos 10 pro, linux
    Network Routerzyxel keenetic giga ii
    Sep 2017
    5
    asus z270 e gaming sound problems
    Hello I experience many problems with my internal sound chip.
    when I connect the headphones to the front connector I hear a strange noise in the right channel. so I use the rear connector. but even then, everything is not very good. sometimes the sound becomes very distorted and I have to unplug and reconnect my headphones again. I'm almost sure that this is not a hardware problem since there are no problems with Linux on the right channel. so it is interesting that as soon as I put together a computer there were no problems. I reinstalled windows and removed the driver, but it does not help.
    erik-pro PC Specs
    Processori7 7700K
    Sound Cardinternal
    Monitorno
    Storage #11 tb hdd
    Storage #2500gb hdd
    Sep 2017
    5
    Quote Originally Posted by Chino View Post
    Are you running the latest BIOS?
    yep
    ROG Guru: Grand Master Array
    Oct 2012
    339
    15,255
    Have you checked the front panel audio cable? Make sure it's not touching any other power cables or objects.
    erik-pro PC Specs
    Processori7 7700K
    Sound Cardinternal
    Monitorno
    Storage #11 tb hdd
    Storage #2500gb hdd
    Sep 2017
    5
    I already said that this is not a hardware problem. in Linux there is no such
    erik-pro PC Specs
    Processori7 7700K
    Sound Cardinternal
    Monitorno
    Storage #11 tb hdd
    Storage #2500gb hdd
    Sep 2017
    5
    Quote Originally Posted by erik-pro View Post
    Yes I checked
  7. #7
  8. #8
    erik-pro PC Specs
    Processori7 7700K
    Sound Cardinternal
    Monitorno
    Storage #11 tb hdd
    Storage #2500gb hdd
    Sep 2017
    5
    Which version of Windows are you using?
    I checked the wire a second time and realized that it is close to the power supply of the processor. moved the noise far away. Only the problem with distortion of sound after some time remained
    windos 10
  9. #9
Tags for this Thread
