Page 4 of 4 FirstFirst ... 2 3 4
Results 31 to 40 of 40
  1. #31
    ROG Enthusiast Array leyabe PC Specs
    leyabe PC Specs
    MotherboardASUS ROG Zenith Extreme
    ProcessorAMD Threadripper 1950X
    Memory (part number)Team Dark Pro 16GB (4 x 8GB)
    Graphics Card #1AMD RX Vega 64 Liquid-cooled
    Sound CardOn-board
    MonitorAcer XR341CK
    Storage #1250 GB M.2 Samsung 960 EVO
    Storage #21 TB SSD Samsung 850 EVO
    CPU CoolerEnermax Liqtech TR4 360 AIO
    CaseCougar Panzer Max
    Power SupplyCorsair HX1000
    Keyboard G.Skill 780 MX
    Mouse Logitech G900 Chaos Spectrum
    Headset Logitech G330
    Mouse Pad Corsair keyboard + mouse mat
    Headset/Speakers Logitech 2.0 + Logitech 5.1
    OS Win10 X64
    Network RouterTP Link Archer C2600
    Sep 2017
    11
    51
    Another update, latest version of the Realtek driver from the Windows Update Catalog does not have the issue.
    Driver version is 6.0.1.8346 and I got it from here https://www.tenforums.com/drivers-ha...r-version.html
    (which links to the Windows Update Catalog).
    This version does install fine, does have the "SupremeFX" control panel, and the Amplification level does survive a reboot.
    I just find it weird that this driver is not offered on ASUS's support page, and isn't even listed on Realtek's website either.
  2. #32
    New ROGer Array
    Jan 2014
    1
    I installed version 6.0.1.8318 from that link without uninstalling my previous version (8.0.1.8273 on a Maximus X Code) beforehand and after the initial please wait message it said some file couldn't be found. After that it closed and nothing else happened. I rebooted and still have the SupremeFX setup, and it says I'm running 6.0.1.8318. I set my amplify level to performace (as someone noted before it's spelled wrong) and rebooted a couple times, it did stick. I listened to some music and videos, it sounds like it's on performance.
    Anyone know what the impedance range is for the 3 amplify settings? My headphones are rated for 32 ohms and every time I plug them in, front or back, impedance detection states they are higher than 110 ohms and sets it to extreme. This is definitely not the case as listening to anything on extreme is painful with this headset. I'm just assuming performance is good for 32 ohms but can't definitively tell since there is no description.
  3. #33
    ROG Guru: White Belt Array
    Nov 2014
    18
    113
    Can someone the official version 6.0.1.8339 installs ok and has the amplification setting fixed? https://www.asus.com/Motherboards/RO...Desk_Download/
  4. #34
    leyabe PC Specs
    Sound CardOn-board
    MonitorAcer XR341CK
    OS Win10 X64
    Sep 2017
    11
    51
    Quote Originally Posted by elmor View Post
    Thanks elmor, I confirm that the issue is fixed in the version 6.0.1.8339 that you linked.
    To clarify, I still get the "scratchy" audio at the "Extreme" amplification setting starting between 70 to 80% volume (below 70% the sound is crystal clear even at "Extreme"). But at least the amplification setting will stick after rebooting now.
    Thanks again!
  5. #35
    Jan 2018
    37
    Angry
    I need a fix for z370-g gaming too!
  6. #36
    ROG Enthusiast Array klepp0906 PC Specs
    klepp0906 PC Specs
    MotherboardMAXIMUS X FORMULA
    Processor8770K
    Memory (part number)CMR16GX4M2C3600C18
    Graphics Card #12080TI
    Sound CardREALTEK/ONBOARD
    MonitorU2718Q
    Storage #1970 EVO PLUS 1TB
    Storage #2BARRACUDA 8TB X9
    CPU CoolerEK SUPREMACY/WATER
    Case900D
    Power SupplyNEX1500
    Keyboard BLACKWIDOW CHROMA V2
    Mouse NAGA TRINITY
    Headset TIAMAT V2
    Mouse Pad VESPULA V2
    OS WINDOWS 10 PRO 1903
    Network RouterARRIS BGW210
    Jun 2014
    59
    same issue on z370 maximus x formula.
    been through a plethora of drivers. they default to "performace" (engrish) when i have my headset set to stereo, but the minute i change it to 7.1 it defaults to extreme. Extreme sounds better in general, but changing the volume knob on my headset (razer tiamat 7.1 v2) i can hear feedback through the headset. Or in retroarch when navigating the menu at extreme i get crackles with the navigation click sound.
    same as the distortion in the windows cancel sound effect thing.
    everywhere else its fine more or less.
    someone said realtek is blaming it on M$ interrupts or some such? has anyone tried changing to MSI using MSI mode utility? it would need to be re-done every time you update your drivers which is a pain, and if it alleviated it one would question why its not the default.
    of all my drivers only 2 dont use MSI, nvidias gpu driver, and realteks audio driver. the rest all do.
  7. #37
    ROG Member Array EviLFazZ PC Specs
    EviLFazZ PC Specs
    MotherboardROG Zenith Extreme Alpha X399
    ProcessorAMD Ryzen 2950X
    Memory (part number)G.Skill DDR4 4x 8GB 3600MHz
    Graphics Card #1EVGA 2080Ti Ti FTW3 Ultra
    Sound CardAsus Xonar HD1.3 with daughter board
    MonitorLG 31MU97Z-B
    Storage #1Samsung 960 EVO 256GB
    Storage #2Samsung 840 PRO 256GB
    CPU CoolerCorsair AiO H110i v2
    CaseCoolmaster Cosmos (original)
    Power SupplyCorsair HX1000i
    Keyboard Corsair K95 RGB (Edition 3)
    Mouse Logitech MX Ergo Trackball (Plus Edition)
    Headset AKG K812 Pro and Sennheiser HD 380 Pro
    Mouse Pad The table, one of our cats, my lap, the floor, my sexy other, etc
    Headset/Speakers Mission; Floor-standers, Bookshelves, Dipoles and Centres, and two REL Subwoofers
    OS Windows, Ubuntu and Steam OS
    Network RouterTP-Link AC5400
    Accessory #1 Valve Index
    Accessory #2 8x Steam Controllers
    Accessory #3 Logitech Brio WebCamera
    Nov 2017
    7
    Exact same issue here since I first got my (crappy low budget ...) ROG Zenith II Extreme Alpha way back in March 2020 and the drivers have not changed or been updated since.
    My only work around is setting this 'so called' high end motherboard to the lower audio quality and then it is stable/works, anything sends ear-deafing noise to all ports front and rear (depending which ever is enabled at the time of changing and starting ANY audio, films, music, web based, games, etc)
    I have requested help from Asus directly a few times now and the only thing they keep saying, is send the board for RMA. Great, so I loose my build for a year, whilst they possibly figure out, pay £££GBP's to send from the UK to some distant international address (last time was the US), whilst having costly parts just sit here do nothing and we all know, it is not hardware, it is software based, as this is not the first time this happened (all their Threadrippers boards have suffered the same until they did 'something' about it)
    20+ years with Asus and I seriously regret the last 3 years of wasting my time and (huge amounts of) money with them and their zero support for such basic things
  8. #38
    New ROGer Array menaquinone PC Specs
    Laptop (Model)desktop
    MotherboardASUS Prime Z370-A
    ProcessorIntel Core i7-8700K
    Memory (part number)don't wanna say
    Graphics Card #1none
    Sound Cardnone/on_mobo
    Monitordon't wanna say
    Storage #1SSD
    CPU Coolerdon't remember
    Casedon't remember
    Power Supplydon't wanna say
    Keyboard don't wanna say
    Mouse don't wanna say
    OS Windows 7 64bit (temporary)
    menaquinone's Avatar
    Jun 2020
    15
    Post thanks for the solution: aka updated audio drivers/software
    Thank you for this link, I can confirm that the driver(for Windows 7 64bit, which is what I've tested and run) from that url (for mobo ROG ZENITH EXTREME) works for me, even though I've a different mobo(ASUS Prime Z370-A).
    To be more specific, the Amplify Level is now correctly detected as under 51 Ohms and thus set to Performance(it's "Performace" aka typo is still not fixed) and it also sticks(ie. if I set it to Powerful, it remains as such after reboot!). So even if I unplug and plug again(aka replug) the keyboard jack(my headphones/earbuds are plugged into the keyboard, and the keyboard is (re)plugged into the PC in the back, in this case) it will still properly detect it as under 51Ohms with this updated driver and set it to "Performace". The driver being, (for mobo ROG ZENITH EXTREME), as follows:
    Version 6.0.1.8746 2019/12/03
    686.47 MBytes
    Realtek Audio Driver
    Updated User Account Control verification mechanism to match the revised requirements of the kb4524147 hotfix
    sha256: 364d2c3b51eb729a286686f5c0f37b59b532f3e822db08f87f 007f95ad535616
    filename: V8746_WHQL_191203_SS3.6.45_FF03_WIN7_19H1.zip
    If someone could place that updated driver into the Prime Z370-A downloads, aka here: https://www.asus.com/us/Motherboards...Desk_Download/ that would be nice.
    Because the one from there(currently) is:
    Version 6.0.1.8199 2017/09/04
    738.83 MBytes
    Realtek Audio Driver V6.0.1.8199 for Windows 7 64bit &Windows 10 64-bit---(WHQL).
    sha256: 50b7989300b1e876e22aa6a2adc6d3695ae79dc0f4e6d02799 0d0fdf1c7e8233
    filename: Realtek_AudioDriver_Win10_V6018199_20170904.zip
    and with this one I get equal or higher than 110 ohm detection, and thus set to Extreme which distorts the sound (no crack or pops, but it's too amplified hence distorted) and this happens when I replug too, and also after I reboot the setting won't stick to what I set it! All fixed, as mentioned above with the ROG ZENITH EXTREME audio driver (aka the newer driver).
    Here's screenshots with this old/faulty driver:
    Here's screenshots with the new/working ROG ZENITH EXTREME audio driver which does work on ASUS Prime Z370-A too(superficially tested though):
    2 screens from first reboot, after install(AsusSetup.exe run, then rebooted manually):
    2 more screens after clicking the green socket and setting from Speakers to Headphones:
    Thanks all for making this happen!
  9. #39
    New ROGer Array
    Apr 2020
    14
    I've got a Maximus XII Extreme motherboard and with latest drivers I'm experiencing the automatic Amplify level switching based on readings by the impedance sensor. Windows version is 2004. I've tried the drivers that seem to have helped other users, taking them from Zenith Extreme download page for Windows 10 (namely 8339 and 8746). With the first one I don't get any sound from headphones connected to front panel jack, with the second one nothing changes, unfortunately, compared to newest drivers: Realtek GUI keeps on switching Amplify level based on what the impedance sensor reads, values that are hardly different from the ones I get installing the most recent drivers. Anything special in the installation procedure I could have missed?
    However, I'm confused, if this is normal behaviour why letting the user change manually a setting that will be reset every time he plug/unplug headphones?
    If instead it is a bug/issue (and not a recent one, it seems!) it really sucks, especially after paying almost 1000 euros‚¬ for a so-called top-tier motherboard.
  10. #40
    ROG Enthusiast Array Tux-box1 PC Specs
    Tux-box1 PC Specs
    MotherboardROG Zenith II Extreme Alpha 2
    ProcessorAMD Tyzen Threadripper 3990x
    Memory (part number)F4-3200C14Q2-128GTZR
    Graphics Card #1ROG-STRIX-RTX2080TI-O11G-GAMING
    Storage #1SamSung 970 EVO Plus M.2
    CPU CoolerCustom Loop
    Case1000d
    Power SupplyEVGA SuperNOVA 1300G2 (FM)
    OS Windows / Linux
    Dec 2017
    40
    I started a thread before finding this one, https://rog.asus.com/forum/showthrea...-volume-static
    What I'm experincing is: at random timing my audio will go full valume static, it's very painful.
    I thought the issue was with Nahimic, as this handles the Sonic Studio/Sonic Radar stuff. If I'm wrong on this let me know.
    I moved my head set connections to the front, has anyone else tried the front audio connectors? For now I haven't run in to the issue but I've not had the time to verify.
    I prefer to use the rear as that works best with my desk setup. Before anyone asks, my audio cables are shilded and routed specficly to aboid interferance and cross noize, the computer is on dedicated UPS(Pure Sine) by it's self and I get the same issue on line power, its the only thing on this circuit.
