Results 1 to 7 of 7
Thread: AC5300 woes
10-04-2017 01:20 AM #1
- Join Date
- Aug 2014
- Reputation
- 10
- Posts
- 8
AC5300 woes
I just bought a RT-AC5300 in Singapore as a tourist, when i came back to my country all was working fine until i tried to connect my printer using WPS. since then the router started shutting off wifi. I did few factory resets, re uploading of most current firmware. but always the same, sometimes the router wouldn't boot until i reset NVRAM and in the end wifi doesn't work.
Do you have any advise for me? since i am not in Singapore now RMA will be a problem.
Thanks
10-04-2017 03:22 AM #2
haihane PC Specs Motherboard Crosshair V Formula Z Processor AMD FX 8350 Memory (part number) Gskill F3-2400C10-8GTX Graphics Card #1 ASUS HD 6950 Storage #1 WD Velociraptor 1TB Storage #2 Corsair Neutron GTX 120GB SSD CPU Cooler Cooler Master Seidon 120XL Case Cooler Master Silencio 650 Power Supply Corsair HX850 Keyboard Corsair K70 RGB Mouse Logitech G500 OS Windows 7 X64 Network Router Linksys E2500
- Join Date
- Jul 2013
- Reputation
- 106
- Posts
- 618
what does the system log say about that?
log into your router -> System log -> General log -> maybe copy paste it here?no siggy, saw stuff that made me sad.
10-04-2017 09:22 AM #3
- Join Date
- Aug 2014
- Reputation
- 10
- Posts
- 8
after a day with the power off (cable out) it managed to do the wizard with the wifi on.... when wizard was done the wifi went back off... i will try getting the log after another reset once i get less emo about this router lol
10-06-2017 03:34 AM #4
- Join Date
- Aug 2014
- Reputation
- 10
- Posts
- 8
I managed to get my router back to life. but the 2.4ghz band doesn't work (not broadcasting and led is dark). i tried changing settings in the 2.4ghz tab, but nothing helps... the 2.4ghz remains without mac address and chan't choose a channel.
in wireless log 2.4ghz doesn't appear, here is a general log after a fresh reboot:
AC5300routerlog.zip
10-07-2017 01:55 PM #5
- Join Date
- Jul 2013
- Reputation
- 106
- Posts
- 618
disclaimer: i maybe way in over my head about this. the initial reason i asked was because i kind-of experience some problems with my own RT-AC87U router. it's an inferior model to yours, yes; i initially thought the firmware should be similar enough (since in practical business sense, having firmwares being too different from each other across different models cost too much money), so maybe i could use my log and compare it with yours to give some hints on what's happening on both our routers.
i opened both your syslog and mine side by side:
i have a wireless printer too, an epson LX 365 which is connected wirelessly to the RT-AC87U. what's different from yours is that when i first set it up, it was through a USB connection. several steps into the epson wizard, and i get the window to enter the wifi-ssid and password. this is when i know the printer would remember the ssid internally after the setup is done. plugged out the usb, turned the printer back on, tried wireless printing, everything worked (and still works) fine.
i avoided using WPS whenever i could, due to my inherent and perhaps irrational fear about that feature.
like you, i had problems with my own ASUS router prior to firmware update. it manifested when the router nagged me to update firmware. it was working flawlessly before, no matter how much load was thrown into it (4 people using it at any given time, along with their devices) . currently it's on firmware 3.0.0.3.380.7743 <- this firmware caused me some annoying inconveniences: abrupt restarts, killing all connections along with it. i had to wait for it to reboot for the network to re-establish itself.
i'm not a coder by any means, but... wthell, i thought. if we're gonna get ASUS to do anything, then i figured i better do the legwork than just entirely relying on them to fix this PoS (Piece of S***). some things i noticed between both our logs:
- when both our routers starts failing, this line keeps popping out:
Originally Posted by amnon23e's router
Oct 6, 05:16:10 -> 05:22:32 ----> it starts ****ting out tons of texts, most of which i have no idea what that means. but i know this line when i see it
"Oct 6 05:22:32 rc_service: httpd 2650:notify_rc restart_wireless"
when this line comes out on syslog, say bye bye to your wireless connection. then more kernel DROP happens (i have no idea what this is), until i suspect the router forced a restart.
Oct 6 05:24:17 rc_service: httpd 2650:notify_rc reboot
Oct 6 05:24:18 iTunes: daemon is stoped
Oct 6 05:24:18 FTP Server: daemon is stoped
Oct 6 05:24:18 Samba Server: smb daemon is stoped
Oct 6 05:24:18 kernel: gro disabled
Oct 6 05:24:18 Timemachine: daemon is stoped
Oct 6 05:24:18 WEBDAV Server: daemon is stoped
Oct 6 05:24:18 NAT Tunnel: AAE Service is stopped
Aug 1 03:00:13 syslogd started: BusyBox v1.17.4 <- and back it goes to Aug 1. i use this as my own router's bookmark. when i see the dreaded Aug 1, i know this piece of crap restarted itself.
the next thing i noticed was: your log timestamps was much longer than mine for every restart. the errors present in your router are worse than mine. my router could go back and re-enable wireless and wired if i waited long enough, but yours seem stuck with all the errors, and then it tried to restart itself again. this went on until Oct 6 05:51:56. look at your own log -> rc_service: wpsaide 534:notify_rc start_wps_method. looking at it, and by pure guessing, it seemingly tells me that it tried to restart WPS over and over and over but failed and tried and failed and tried and failed and tried till it gave up and it just attempted to restart everything at Oct 6 06:25:21 rc_service: httpd 548:notify_rc reboot.
this vicious cycle kept going on and on and on :/
i guess, just as a temporary measure. disable WPS entirely, and factory reset again with just one computer connected to it. see if that makes anything better, look at the log for any irregularities.no siggy, saw stuff that made me sad.
10-07-2017 03:46 PM #6
Korth PC Specs Motherboard ASUS X99 R5E (BIOS2101/1902) Processor Haswell-EP E5-1680-3 SR20H/R2 (4.4GHz) Memory (part number) Vengeance LPX 4x8GB SS DDR4-3000 (CMK32GX4M4C3000C15) Graphics Card #1 NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB) Graphics Card #2 NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB) Sound Card JDS Labs O2+ODAC (RevB), USB2 UAC1 Monitor ASUS PG278Q Storage #1 Samsung 850 PRO 512GB SSDs, 4xSATA3 RAID0 Storage #2 Comay BladeDrive E28 3200GB SSD, 8xPCIe2 CPU Cooler Raijintek NEMESIS/TISIS, AS5, 2xNH-A14 Case Obsidian 750D (original), 6xNH-A14 Power Supply Zalman/FSP ZM1250 Platinum Headset Pilot P51 PTT *modded* OS Arch, Gentoo, Win7x64, Win10x64 Network Router Actiontec T3200M VDSL2 Gateway Accessory #1 TP-Link AC1900 Archer T9E, 1xPCIe Accessory #2 ASUS/Infineon SLB9635 TPM (TT1.2/FW3.19) Accessory #3 ASUS OC Panel I (FW0501)
- Join Date
- Mar 2015
- Reputation
- 152
- Posts
- 2,719
[/Korth]
10-29-2017 05:05 PM #7
JustinThyme PC Specs Laptop (Model) G752VY-DH72 Motherboard Rampage VI Extreme Processor I9 9940X Memory (part number) 64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17 Graphics Card #1 ASUS Strix 2080Ti O11G @ 2.1GHz Graphics Card #2 ASUS Strix 2080Ti O11G @ 2.1Ghz Graphics Card #3 ROG Nvlink Graphics Card #4 Have to feed animals Sound Card External Audioengine D1 24 bit 192kbps DAC Monitor ASUS PG348Q @ 100Hz Storage #1 Intel 905P 480GB U2 flavor Storage #2 Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1 CPU Cooler HeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS Case Phanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM Power Supply Corsair AX 1500i Keyboard ASUS Claymore Mouse ASUS Spatha, Logitech MX Master Headset Sennheiser HD 700 Mouse Pad ASUS ROG Sheath Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub OS Win10 Pro 1809 Network Router NetGear NightHawk X10 Accessory #1 NetGear Prosafe 10GBe Switch Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
- Join Date
- Nov 2013
- Reputation
- 144
- Posts
- 3,854
