Help! Asus aura problem! Cant install at all!!!!
GrandHitman
I cant install any version of AURA It just says Remote Procedure failed to call. Im running Win10 64bit my PC Specs are
Mobo:ASUS ROG STRIX Z270E
GPU:ROG-STRIX-GTX1080TI-O11G-GAMING
RAM:G.Skill TridentZ 32GB
CPU Cooler:Corsair H100i V2
OS:Win 10 64 Bit
I've tried everything nothing will work can someone help me?
hector61669
Have you tried running one stick of ram at a time?
Also check your services, "Remote Procedure Call" should say started. Remote Procedure call Locator should be on Manual
Yes I have and I tried that too... Still no progress at all
AkaNe0
OS:Win 10 64 Bit
As hector mentioned, this issue seems to be related to your OS.
Try the following as well:
In Services, scroll down to "Remote Procedure Call" and make sure the status says "Started" and set to Automatic.
The second "RPC Locator" should be set to "Manual".
If the issue persists, please try to perform a scan of your computer.
And don't forget, Keep pushing it !
