Page 1 of 5 1 2 3 ... LastLast
Results 1 to 10 of 43
    ROG Guru: White Belt Array mmohamed2's Avatar
    Jul 2017
    97
    Rgb keyboard issue gl553d
    I changed the color of the keyboad TO ALL WHITE BUT THE RIGHT PART LOOKS YELLOW
    CHECK THE IMAGES
    So , software or hardware problem?
    Is it because of using 4 different colors for long time?
    ROG GAMING CENTRE V2.0.3
    HELP!
    ROG Guru: Yellow Belt Array Bran187 PC Specs
    Bran187 PC Specs
    Laptop (Model)GL502VMK
    MotherboardMSI Z97 SLI Krait Edition
    Processori7 4790
    Memory (part number)16 GB GSkill DDR3
    Graphics Card #1EVGA GTX 1070
    MonitorHP Pavilion 32q
    Storage #1120 GB SSD
    Storage #21TB HDD
    CPU CoolerCM 212
    CaseFractal Define R4
    Power SupplySeasonic 650W
    Keyboard Corsair K55
    Mouse Corsair M65 Pro
    Headset Plantronics Rig
    Mouse Pad Glteck XXL
    OS Windows 10
    Oct 2012
    15
    204
    Quote Originally Posted by mmohamed2 View Post
    CHECK THE IMAGES
    HELP!
    Does setting it to a color other than white exhibit the same type of 'variance'? Try like a light blue, or a light yellow, and see if it does the same? I imagine the darker/deeper the color, the less noticeable the effect would be. Just trying to help you narrow down whether its a hardware or software problem.
    Also have you tried reinstalling the keyboard drivers/lighting software? That would be the first thing I would try.
    ROG Guru: Black Belt Array Korth PC Specs
    Korth PC Specs
    MotherboardASUS X99 R5E (BIOS2101/1902)
    ProcessorHaswell-EP E5-1680-3 SR20H/R2 (4.4GHz)
    Memory (part number)Vengeance LPX 4x8GB SS DDR4-3000 (CMK32GX4M4C3000C15)
    Graphics Card #1NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Graphics Card #2NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Sound CardJDS Labs O2+ODAC (RevB), USB2 UAC1
    MonitorASUS PG278Q
    Storage #1Samsung 850 PRO 512GB SSDs, 4xSATA3 RAID0
    Storage #2Comay BladeDrive E28 3200GB SSD, 8xPCIe2
    CPU CoolerRaijintek NEMESIS/TISIS, AS5, 2xNH-A14
    CaseObsidian 750D (original), 6xNH-A14
    Power SupplyZalman/FSP ZM1250 Platinum
    Headset Pilot P51 PTT *modded*
    OS Arch, Gentoo, Win7x64, Win10x64
    Network RouterActiontec T3200M VDSL2 Gateway
    Accessory #1 TP-Link AC1900 Archer T9E, 1xPCIe
    Accessory #2 ASUS/Infineon SLB9635 TPM (TT1.2/FW3.19)
    Accessory #3 ASUS OC Panel I (FW0501)
    Korth's Avatar
    Mar 2015
    152
    2,718
    Is a similar difference noticeable when changing the full keyboard to other colours? If one particular colour/tint always (or never) appears in the same region then it could be a hardware fault, something wrong with the LED logic part or connector ribbon or whatever.
    I'm going to guess - just a guess - that it's software. AURA is still buggy.
    [/Korth]
    Jul 2017
    97
    Quote Originally Posted by Bran187 View Post
    Yes,right,the darker colors are less noticeable but for the others like light blue for exemple the right part is almost green :/
    I tried reinstalling and installing old version of aura core but the same problem, i don't know if the new preview version of windows 10 16299.15 cause this problem or not
    Jul 2017
    97
    Quote Originally Posted by Korth View Post
    It's the same for all colors
    i hope it's software problem
    I notice this problem after the windows update to build 16299.15
    I don't remember if there's the same problem in the old win10 version or not
    Jul 2017
    97
    PLEASE ANYONE HAVE THE SAME PC (GL553VD i7 8RAM) CONFIRM THE ISSUE
  7. #7
    Jul 2017
    97
    Anyone can take a photo of the keyboard Please!!
  8. #8
    Jul 2017
    97
  9. #9
    Apr 2017
    14
    91
    Did not notice such a thing
    mmohamed2, hi!
    I did not notice any heterogenety in colour distribution:
    White (255; 255; 255)
    Yellow (255; 255; 0)
    I only noticed that all right diodes of lower row make a little bit green, but my camera can not catch this:
    Do you perform a test similar to dead pixel test for monitors? I.e. toggle only red diodes (255; 0; 0), then only green (0; 255; 0) and then blue (0; 0; 255)? If these primary colours did not alter over all keyboard, problem is not in hardware.
    Cheers!
  10. #10
    Korth PC Specs
    MonitorASUS PG278Q
    Korth's Avatar
    Mar 2015
    152
    2,718
    Quote Originally Posted by Lord Obsidian View Post
    Is this not what you meant?
    I think if all the primary colours do not properly show then the problem is hardware. Or do you mean the opposite?
    That is a very good testing approach, though.
    [/Korth]
