Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
    ROG Member Array
    Sep 2017
    13
    Front Panel Audio Connectors not working PROPERLY
    I am currently having problems with the front audio connectors on my S340 Elite case.
    HERE IS WHAT HAPPENS:
    When I plug headphones into front jack I get a crackling noise (no audio) but it is worth to note that interaction with the computer like clicking buttons and doing things that normally wouldn't create a sound and also plugging the HDMI cable to the graphics card make the crackling noise change slightly.
    When I have got a speaker plugged into the back LINE OUT the audio works fine. But when I plug my headphones into the front connector WHEN THE BACK SPEAKER IS PLUGGED IN and click 'headphones' in the asus realtek audio manager I am getting clear audio for about 5 seconds until it goes crackly again but then the audio starts to come out the speaker again clearly so I am not sure what that is all about but I believe this proves that there is a clear connection to the front audio connector so I just believe there is a driver/software issue but I am now sure how to fix it so I would like any help anyone can offer thanks.
    ROG Guru: Black Belt Array Korth PC Specs
    Korth PC Specs
    MotherboardASUS X99 R5E (BIOS2101/1902)
    ProcessorHaswell-EP E5-1680-3 SR20H/R2 (4.4GHz)
    Memory (part number)Vengeance LPX 4x8GB SS DDR4-3000 (CMK32GX4M4C3000C15)
    Graphics Card #1NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Graphics Card #2NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Sound CardJDS Labs O2+ODAC (RevB), USB2 UAC1
    MonitorASUS PG278Q
    Storage #1Samsung 850 PRO 512GB SSDs, 4xSATA3 RAID0
    Storage #2Comay BladeDrive E28 3200GB SSD, 8xPCIe2
    CPU CoolerRaijintek NEMESIS/TISIS, AS5, 2xNH-A14
    CaseObsidian 750D (original), 6xNH-A14
    Power SupplyZalman/FSP ZM1250 Platinum
    Headset Pilot P51 PTT *modded*
    OS Arch, Gentoo, Win7x64, Win10x64
    Network RouterActiontec T3200M VDSL2 Gateway
    Accessory #1 TP-Link AC1900 Archer T9E, 1xPCIe
    Accessory #2 ASUS/Infineon SLB9635 TPM (TT1.2/FW3.19)
    Accessory #3 ASUS OC Panel I (FW0501)
    Korth's Avatar
    Mar 2015
    152
    2,719
    If you can, try routing the front audio cable away from any power-carrying cables. Just an idea.
    I see some random complaints about "defective" or "poor quality" audio in that chassis model. If the cables are low-quality or poorly-shielded then you might want to upgrade/replace/mod them.
    Which motherboard and BIOS version, operating system, ASUS audio software, Realtek driver versions, and headphone model/impedance, etc?
    [/Korth]
    ROG Member Array
    Sep 2017
    13
    I do not believe this is interference because for the first 5 seconds I plug my headphones in and select headphones in realtek audio manager the audio is crystal clear this is why I am kinda confused and believe this is a software issue.
    BIOS VER: 0906
    OS: Windows 10 Home (64 bit)
    Audio Software: Sonic Studio 3, Latest Ver of Realtek Audio Manager from Asus website
    MOBO: Asus Strix z270f
    My headphones are turtle beach but I know they are not the problem
    What is impendence?
    So yeah, I believe this is a driver/software issue but I don't know how to fix it so any help will be appreciated.
    Thanks
    Korth PC Specs
    MonitorASUS PG278Q
    Korth's Avatar
    Mar 2015
    152
    2,719
    If it was a software issue then it would likely sound the same regardless which audio output you use. The software processes digital audio data, the same data regardless which output is used, not different processing for each output, it gains noise only after it's passed through the DAC hardware and has become an analog waveform.
    That mobo uses one codec (SupremeFX S1220A aka Realtek ALC1220) for all audio ports. Some audio-grade op-amps (one RC4580, two OPA1688), audio-grade capacitors, and other parts (for "de-pop" and filtering) are attached directly to one stereo (L+R) channel audio output for the headphones. I couldn't find whether this headphone-dedicated enhanced audio is connected to the rear outputs or the front outputs, but I note that only the rear circuitry has full-channel PCB-layer isolation and shielded parts.
    It could be a software issue, but I think it's almost definitely hardware.
    http://www.tomshardware.com/forum/26...o-static-noise
    [/Korth]
    ROG Member Array
    Sep 2017
    13
    Okay, it was just that I was a bit confused why it was working for the first 5 secs and I swear the software sometimes mutes one output it another output is being used but I believe what you are saying is right and I am going to remove the Hard Drive and see if I am still getting the static and I'll go from there.
    Will the hard drive being unplugged be enough to stop the interference?
    Korth PC Specs
    MonitorASUS PG278Q
    Korth's Avatar
    Mar 2015
    152
    2,719
    Just unplugging/disconnecting the drive would be enough, it could only cause interference when powered and active.
    But before removing a drive, first test whether it actually causes any interference. Start a large file/folder copy or something to make the drive busy while playing audio through the front jack, it if doesn't add any noise then the drive isn't a problem.
    Likewise you can also listen for increased noise when any chassis fans, CPU fans, GPU fans, or PSU fans spin up; when pumps (on liquid coolers) spin up; when processor performances increase under load; even when system temps begin to increase. You can force these sorts of things to happen on demand by running heavy software. You can also wiggle the audio connector cable (at both ends) and pinch, pull, or flex it a little to determine if it's a source of noise.
    If none of the "active" hardware in your system seems to cause noise then there's no need to remove or replace anything.
    [/Korth]
  7. #7
    ROG Member Array
    Sep 2017
    13
    I have disconnected the Hard Drive plugs and moved the audio cable away from any other cables, but still no difference.
    I am at a bit of a loss here, any other suggestions?
  8. #8
    Korth PC Specs
    MonitorASUS PG278Q
    Korth's Avatar
    Mar 2015
    152
    2,719
    Quote Originally Posted by Korth View Post
    That's all I got, lol.
    Maybe somebody else can offer you a better solution.
    [/Korth]
  9. #9
    ROG Member Array
    Sep 2017
    13
    Welp, thanks for your help anyways.
  10. #10
Tags for this Thread
