Page 1 of 2 1 2 LastLast
Results 1 to 10 of 15
    ROG Member Array
    Sep 2017
    12
    Unhappy Lower temperature than room temp on 0801
    So after installing the 0801 update my idle temps are 28C and load temp 50C. This is with fans set at their lowest speed. At full speed it can go to 16C. My room temp is about 24, how is this happening? I have a 4ghz OC at 1.35V and my cooler is a Enermax TR4 360.
    Anyone has any idea of what can be done? Im afraid of ruining my 1950x :/
    Rolling back to different bios still has the same issue if i overclock.
    Thanks
    ROG Enthusiast Array
    Sep 2017
    45
    Quote Originally Posted by Alexandre_ma View Post
    Thanks
    If I am understanding you properly, your max temp on load it 50C and idle is around 16-28C. That is well withing range and is actually very good. My idle temps are between 18-28C. If I run a CPU-Z stress it does not go higher than 50, if I game its around 30+ (my video card is 69C).
    I use a Termaltake 360 with a push/pull config mounted in the front of my case. I also overclock and I am running 4 GHZ and 3200 mhz.
    ROG Enthusiast Array leyabe PC Specs
    leyabe PC Specs
    MotherboardASUS ROG Zenith Extreme
    ProcessorAMD Threadripper 1950X
    Memory (part number)Team Dark Pro 16GB (4 x 8GB)
    Graphics Card #1AMD RX Vega 64 Liquid-cooled
    Sound CardOn-board
    MonitorAcer XR341CK
    Storage #1250 GB M.2 Samsung 960 EVO
    Storage #21 TB SSD Samsung 850 EVO
    CPU CoolerEnermax Liqtech TR4 360 AIO
    CaseCougar Panzer Max
    Power SupplyCorsair HX1000
    Keyboard G.Skill 780 MX
    Mouse Logitech G900 Chaos Spectrum
    Headset Logitech G330
    Mouse Pad Corsair keyboard + mouse mat
    Headset/Speakers Logitech 2.0 + Logitech 5.1
    OS Win10 X64
    Network RouterTP Link Archer C2600
    Sep 2017
    51
    I think the question is more along the lines of "how can the CPU temperature be lower than room temperature"?.
    I wouldn't expect the CPU temp to be lower than room temperature. It that were the case I would suspect something wrong.
    You're cooling the CPU with air aspirated from the room, it cannot magically give temperatures significantly cooler than what the air you're cooling with is at (maybe by a few degrees due to the fooling factor of moving air, but not by ~10°C, at least I wouldn't think so.
    That said, I'm using the Enermax Liqtech TR4 360 AIO water cooler too, a high performance cooling solution, stock CPU speed (no CPU overclocking), and get idle temps of 30 to 32°C with room temperature of 25°C, which makes sense and is the best temps I ever had with any previous build.
    I'm on BIOS 0801 myself too, so this may not be a BIOS issue, as my temps appear normal to me.
    ROG Guru: Brown Belt Array davemon50 PC Specs
    davemon50 PC Specs
    Laptop (Model)Asus G752VY-DH72 (17") and Asus G752VT-DH74 (17")
    MotherboardAsus ROG LGA2011-v3 Rampage V Edition 10, x99 EATX
    ProcessorIntel Core i7-6950X Extreme 10-core 25MB Cache 3.0 GHz
    Memory (part number)Corsair Vengeance LPX Red DDR4 DRAM 64GB-4x16 3333 (CMK64GX4M4B3333C16R)
    Graphics Card #1Sapphire Nitro Radeon R9 Fury 4GB HBM Backplate
    Graphics Card #2Sapphire Nitro Radeon R9 Fury 4GB HBM Backplate
    Sound CardAsus SupremeFX Hi-Fi Audio DAC
    Monitor(2) Dell UltraSharp U2515H 25-inch monitors
    Storage #1(4) SSD's - Samsung 960 & 970 1TB M.2, Intel 535 480G, Intel 510 250G
    Storage #2(3) HDD's - Western Digital Caviar Black 2TB 3.5-in SATA III 64MB Cache
    CPU CoolerCorsair Hydro Series H80
    CaseCorsair Obsidian Series 650D Black, ATX, Mid Tower
    Power SupplyCorsair Digital AXi-Series AX1200i (1200W) 80+ Platinum Rating
    Keyboard Logitech Wireless K360
    Mouse Logitech Wireless MX Anywhere 2
    Headset HyperX Cloud II
    OS Windows 10 Pro 64-Bit
    davemon50's Avatar
    Apr 2017
    49
    1,055
    Approach temperature will be greater than zero, so your reported low temps are wrong. Unless you are drawing in unmixed air from the A/C system vents and getting colder intake to the case than mixed room air. At equilibrium the CPU temp will match room temp, it heats up from there.
    Davemon50
    ROG Member Array
    Sep 2017
    12
    Quote Originally Posted by leyabe View Post
    Would you mind overclocking to 4 GHz to see if the problem is with the overclocking?
    leyabe PC Specs
    Sound CardOn-board
    MonitorAcer XR341CK
    OS Win10 X64
    Sep 2017
    51
    I tried at 4GHZ and it didn't change anything for me. Well it did increase my idle temps by a few degrees as I expected, but no other change.
  7. #7
    New ROGer Array vpkb1998 PC Specs
    vpkb1998 PC Specs
    MotherboardZenith Extreme X399
    ProcessorRyzen Threadripper 1950X
    Graphics Card #1EVGA Nvidia 1080ti FE
    Storage #1Samsung 960 Pro
    OS Windows 10 Professional
    Oct 2017
    17
    Thanks
    I get the same result with idle/load, and have the same setup. Although, my voltage is 1.395/1.4 using the 4Ghz profile.
  8. #8
    New ROGer Array tr01234 PC Specs
    tr01234 PC Specs
    MotherboardROG ZENITH EXTREME
    ProcessorAMD 1950X RIPPER
    Oct 2017
    3
    Quote Originally Posted by vpkb1998 View Post
    I have the same results with 0803 and the 4Ghz OC Profile. The CPU temperatures have suddenly dropped approx. 10 C after loading the 4Ghz profile. So.. How can that happen unless they are fudging a calibration formula in the BIOS to suit their needs? This is frustrating. What is the real CPU temperature??
    When running under some load (approx. 60w CPU Power), My CPU temp is 29C and water temp is 28C. Great numbers if you are foolish enough to believe it.
    Under a bit larger load and slightly higher room temps, I see my CPU temps sitting slightly below water temperature! I seriously doubt that. This is regular water; not magic water.
    So my question is how and why is this changing!? ..and how do I get an accurate CPU temperature measurement?
  9. #9
    ROG Guru: Brown Belt Array gupsterg PC Specs
    gupsterg PC Specs
    MotherboardAsus Maximus VII Ranger
    Processori5 4690K
    Memory (part number)HyperX Savage 2400MHz 16GB
    Graphics Card #1Sapphire R9 Fury X (1145/545 Custom ROM)
    MonitorAsus MG279Q
    Storage #1Samsung 840 Evo 250GB
    Storage #2HGST 2TB
    CPU CoolerThermalRight Archon SB-E X2
    CaseSilverstone Temjin 06
    Power SupplyCooler Master V850
    Headset/Speakers HyperX Cloud
    OS Win 7 Pro x64 / Win 10 Pro x64
    gupsterg's Avatar
    Feb 2015
    103
    1,011
    Thanks
    Are you using latest OLED FW? (links in here)
    Intel Defector AMD Rebel
    TR 1950X - Custom WC - Asus Zenith Extreme Alpha - G.Skill Trident Z 3400MHz C14 QC - RX VEGA 64
    R5 3600 - Custom WC - Asus Crosshair VII Hero Wifi - G.Skill Ripjaws V 3800MHz C16 - Sapphire HD 5850 Toxic
    24/7 OC: i5 4690K @ 4.9GHz CPU@1.255v 4.4GHz Cache@1.10v - Archon SB-E X2 - Asus Maximus VII Ranger
    Sapphire Fury X (1145/545 ~17.7K GS 3DM FS)
  10. #10
    tr01234 PC Specs
    Oct 2017
    3
    Quote Originally Posted by gupsterg View Post
    I am. My bios is 0701 though. I didn't know about the 0801 beta release. I'll update it this evening.
    Right now my CPU is 17C, water temp. is 27C, and ambient temp is 20.5C. lol This is when it's the furthest out of whack; cold under no load.
    Regards,
    Travis
