Results 1 to 4 of 4
    ROG Member Array
    Dec 2013
    11
    Problem with 1080ti SLI and PCIE m.2
    Dear all,
    I am quite sure you can help me. I have the following set up
    i7 6950x overclocked 4.3Ghz, 1.25V
    Asus Rampage V edition 10
    Dual SLI GTX1080 Ti on ports 1 and 3
    On-Board M.2 with Samsung Pro 960 1tb
    PCI-E m.2 drive (samsung 960 EVO) currently connected on port 2
    Here is my problem, my second GPU is running in 8x. I tried to put the PCIE-M2 drive on port 4 but in that case, my on-board m.2 drive is no longer visible in bios.
    If i remove the PCI-m2, my GPU is running in 16x.
    Looking on the forum threads before installation, i understood that everything should work smoothly if i put the SLI in port 1, 3 and PCIE M.2 drive in port 4. This should be ok with 40 lanes right?
    I am quite sure some expert will be able to guide me to a proper solution to my problem.
    thanks
    ROG Guru: Grand Master Array
    Oct 2012
    339
    15,255
    Quote Originally Posted by ximenji View Post
    No, the PCIe 3.0 x8_4 slot shares bandwidth with the the M.2 and U.2 ports. Since you already have a M.2 drive installed in your M.2 port, you won't be able to install another one in the PCIe 3.0 x8_4 slot.
    You'll have to decide on which route to go. Installing the M.2 SSD in the PCIe 3.0 x8_2 slot will ensure you get the maximum performance from your SSD with the compromise of running your second GPU at x8. Or install the M.2 SSD in the PCIe 2.0 x4_1 slot at which case both your GPU will operate at x16/x16, but your SSD will be limited to PCIe 2.0 performance.
    ROG Member Array
    Dec 2013
    11
    Thanks for your reply. I understand better now.
    What will be the impact on SSD speed if connected on Pcie2x? Overall, i guess maintaining the PCIE s2 oin port 2 might be the most efficient right?
    Try more Array tommiboi PC Specs
    tommiboi PC Specs
    MotherboardSabertooth Mark 1 Z170
    Processor6600K Delidded
    Memory (part number)Gskill 3200
    Graphics Card #1Asus STRIX GTX 980 TI EKWB watercooled
    MonitorAsus PG279Q , Benq XL2411T
    Storage #1Samsung 850 evo SSD 250
    Storage #2M.2 nvme Samsung 960 500 ( 2x in raid 0 )
    CPU CoolerEK Predator 360(rebuild with 280 extra rad)
    CaseBequiet pro 900 Orange
    Power SupplyBequiet Pure Power 9 700W
    Keyboard Corsair rapid fire (RBG)
    Mouse Roccat Kone XTD
    Headset Logitech G933
    Mouse Pad Razer Vespula
    Headset/Speakers Logitech Z4
    OS Windows 10 pro
    Accessory #1 Watch
    Accessory #2 Bracelet
    Accessory #3 1 earing
    Sep 2016
    170
    you will NOT notice any differnce on the m.2 performance ! Unless you can feel the 0.001 sec delay. :-)
    I dont even think you would noitce the differnce between a SSD and M.2 ssd.
    I have m.2 in raid zero..... Just because I can. But it has no real world improvement vs a normal ssd.
    Try more, Try harder, Try and previal
