Results 1 to 6 of 6
    nb Array NeoBeum PC Specs
    NeoBeum PC Specs
    Laptop (Model)G751JY
    MotherboardHM87
    Processori7-4860HQ
    Memory (part number)32Gb Kingston Hyper-X
    Graphics Card #1nVidia GTX980M
    Storage #1Samsung 950 Pro NVMe 256 Gb, Samsung 850 Pro 512 Gb
    Storage #22 TB HGST 7KRPM RAID0
    OS Windows Server 2016 Datacenter
    NeoBeum's Avatar
    Aug 2015
    175
    Intel Wireless AC 7260 - Possible Fix - Need Guinea Pigs
    The Automatic Install for the Intel ProSet Wireless Setup - forgets to install the Bluetooth Highspeed stuff for the AC 7260 -
    I'm still in the middle of testing - and moving up to 18.33 with these installed:
    BTHS (Bluetooth Highspeed)
    CAM (Cloud Access Manager)
    WiFi Display Link Driver (WiFi Display)
    Using Intel Bluetooth Driver 19.60.
    The installation process is different to the standard installation -
    Uninstall all WiFi drivers and Bluetooth drivers - so they appear as unknowns.
    Purge drivers in the Windows Driver Store with PNPUTIL, in Command Prompt.
    Code:
    C:\Windows\System32>  PNPUTIL -E
    That will dump the list of drivers installed...
    Code:
    Published name :            oem26.inf
    Driver package provider :   Intel
    Class :                     Network adapters
    Driver date and version :   07/29/2015 18.12.1.2
    Signer name :               Microsoft Windows Hardware Compatibility Publisher
    Published name :            oem25.inf
    Driver date and version :   04/30/2015 15.18.0.1
    Published name :            oem18.inf
    Driver date and version :   04/30/2015 15.11.0.9
    Published name :            oem20.inf
    Driver date and version :   04/30/2015 15.17.0.1
    if you need to get rid of existing Wireless drivers... find the relevant oem## and use the right ##
    Code:
    PNPUTIL /F /Delete-Driver oem26.inf
    That will delete the drivers:
    Installation Process from a Clean Driver Store with No Wireless Drivers
    Go to Device Manager, You should immediately see devices that need installation. One is the Bluetooth Card, the other is the Wireless Card.
    You need to install the Bluetooth Driver First.
    If you have the AC7260 - In device manager go to
    [V]iew >> De[v]ices by connection
    (Press ALT then V and V again for quick shortcut using keyboard)
    Look for the Bluetooth device in:
    USB 3.0 eXtensible Host Controller >> Intel USB 3.0 Root Hub >> Intel Wireless Bluetooth
    Install the 19.60 Bluetooth Drivers: BT_19.60.0_64_Win10.exe
    https://www.intel.com.au/content/www...000005489.html
    (The other option is to grab the expanded admin install I attached to this post and go to the Utilities folder, and use DPInst.exe)
    Now to install the Wireless AC
    Use the ASUS Download package for 18.12 & Extract the contents.
    Don't use Setup.exe, and instead, navigate to the directory:
    WLAN_Intel_Win10_64_VER181212\Install\data
    Here, Manually install :
    1. Driver.msi
    2. BTHS.msi
    3. WiFi.msi
      (optional)
    4. CAM.msi
    Next we need to set the configuration - for the Wireless Card - head on over to Network Adapters in control panel
    If you hate windows 10 Shell Settings, press WindowsKey+R and run this command
    Code:
    cmd /c "mkdir C:\'Panel'.{ed7ba470-8e54-465e-825c-99712043e01c}"
    That will drop an unnamed shortcut which you can later rename, and this short cut looks like the Control Panel shortcut. Except... better inside...
    Go to the Network and Sharing Centre Section, Group by Type, and View Network Connections.
    Go to the Wireless Connection Icon, go to P[r]operties, and [C]onfigure:
    These are some settings to change or check
    802.1n Channel 2.4GHz ---- (Auto (unless your router is transmitting 20MHz band))
    802.1n Channel 5.2GHz ---- (Auto (unless your router is transmitting 20MHz band))
    Ad Hoc CHannel 802.1 b/g ---- 1
    Ad HoC QoS Mode ---- WMM Disabled (Enable if you use Cloud Access)
    ARP offload for WoWLAN --- Disabled
    Bluetooth AMP ---- Disabled (Unless you constantly use Bluetooth for tethering or large transfers or WiFiDi - this is Bluetooth Highspeed PHY)
    Fat Channel Intolerant ---- Disabled
    GTK rekeying for WoWLAN ---- Disabled (Unless you use magic packet or wake on lan features)
    HT Mode ---- VHT Mode
    Mixed Mode Protection ---- RTS/CTS Enabled
    NS Offload for WoWLAN ---- Disabled (Unless you use magic packet or wake on lan features)
    Packet Coalescing ---- Disabled (Unless you use magic packet or wake on lan features)
    Preferred Band ---- Your choice
    Roaming Aggressiveness ---- Medium (Tweak as required)
    Sleep on WoWLAN Disconnect ---- Disabled (Unless you use magic packet or wake on lan features)
    Throughput Booster ---- Disabled (Unless you have Fibrelink or using 5.2GHZ Band AC)
    Transmit Power ---- Highest
    U-APSD Support ---- Disabled
    Wake on Magic Packet ---- Disabled (Unless you use magic packet or wake on lan features)
    Wake on Pattern Match ---- Disabled (Unless you use magic packet or wake on lan features)
    Wireless Mode ---- 802.11 a/b/g
    Make sure that the System cannot power down the device for power saving in the 'Power Management Tab'.
ID:	68030 Click image for larger version.
    Go to the Super Control Panel you made and 'Edit Power Plan' >> [C]hange advance power settings
    Make sure that 'Maximum Performance' is used in Wireless Adapter Settings and
    'USB Settings' suspend is Disabled if frequently using Bluetooth
    Recap if everything done right in Control Panel >> Programs and Features:
    <img src="eckyeckypoobah.gif" onerror="alert('An error occurred loading the image.')" />
    Banned Array JustinThyme PC Specs
    Laptop (Model)G752VY-DH72
    MotherboardRampage VI Extreme
    ProcessorI9 9940X
    Memory (part number)64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17
    Graphics Card #1ASUS Strix 2080Ti O11G @ 2.1GHz
    Graphics Card #2ASUS Strix 2080Ti O11G @ 2.1Ghz
    Graphics Card #3ROG Nvlink
    Graphics Card #4Have to feed animals
    Sound CardExternal Audioengine D1 24 bit 192kbps DAC
    MonitorASUS PG348Q @ 100Hz
    Storage #1Intel 905P 480GB U2 flavor
    Storage #2Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1
    CPU CoolerHeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS
    CasePhanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM
    Power SupplyCorsair AX 1500i
    Keyboard ASUS Claymore
    Mouse ASUS Spatha, Logitech MX Master
    Headset Sennheiser HD 700
    Mouse Pad ASUS ROG Sheath
    Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub
    OS Win10 Pro 1809
    Network RouterNetGear NightHawk X10
    Accessory #1 NetGear Prosafe 10GBe Switch
    Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
    Nov 2013
    144
    3,857
    Im not sure Im following you here. What are you trying to fix.
    Mine works fine with only two steps.
    Download and install the proset software and driver from Intel and install.
    Download and install the BT from Intel and install.....done.
    This method works fine for me on G74SX, G751JL, G751JY and G752VY. First 3 have the AC 7260 and the latter has the 8260.
    NeoBeum PC Specs
    MotherboardHM87
    Processori7-4860HQ
    NeoBeum's Avatar
    Aug 2015
    175
    There's a crash with WLANExt.exe - but during my testing over the weekend I didn't realise that one of the bluetooth controllers got through windows update - which meant everything I thought is backwards - instead of missing intel programs - it's the intel programs fighting with the windows 10 shell ui that are causing the crashes - if one of the proset packages are installed and if windows updates finds a new driver set that doesn't match the proset installed - and the device tries to configure WLAN when the connection drops out or sleeps - is probably the cause of the problems
    ROG Guru: Gold Belt Array Clintlgm PC Specs
    Clintlgm PC Specs
    Laptop (Model)Asus G752VY DH72
    MotherboardAsus Z97 Pro WiFi and /Z97 Pro A
    ProcessorI7 4790K
    Storage #1512 GB M.2 Samsung 960 Pro
    Storage #21 TB Samsun 850 Pro
    CaseCool Master Haf
    OS Win 8.1 Pro and Win 10 Pro
    Clintlgm's Avatar
    Jul 2012
    105
    4,137
    Yea that why I have WU driver updates blocked on all my units.
    Thanks for posting all this, sure hope I never have to use it.
    G752VY-DH72 Win 10 Pro
    980m GTX 4 GB
    32GB DDR 4 Standard RAM
    Z97 PRO WiFi I7 4790K
    Windows 10 Pro
    Z97 -A
    Windows 10 Pro
    ProcessorI9 9940X
    OS Win10 Pro 1809
    Nov 2013
    144
    3,857
    I'm with Clint, I never allow windows to update drivers for anything. Windows updates, Office updates, security updates Yes. Any hardware that has a vendor page where you can get updates, not no but HE double hocky sticks NO! I dont ven get them from the ASUS site. AC7260 is an intel device so thats where I go to look for drivers when needed.
    ROG Guru: Blue Belt Array Gps3dx PC Specs
    Gps3dx PC Specs
    Laptop (Model)Current: G751JT | Retired: G55VW, G51JX
    MotherboardInc M.2 slot
    Storage #1Samsungs EVO 850 128GB
    Storage #21TB HGST Travelstar 7K1000 (HTS721010A9E630)
    CPU CoolerMother Nature & Thermodynamics laws
    Mouse Logitech MX 518
    Headset/Speakers Logitech T6060
    OS Cleaned installed Windows 10 HOME x64
    Accessory #1 Leap Motion
    Feb 2015
    71
    784
    @Justin wrote:
    "AC7260 is an intel device so thats where I go to look for drivers when needed" - I agree, but the latest isn't always the stable/free of problems ( especially on win10).
    The instability of 7260AC in combination with win10, is well known throughout the web - asus G serie laptops are not alone.
    issues inc random windows freezes, random connection hang-ups, waking from sleep and more.
    on my win10 1703, After having latest ProSet from intel with issues, I've reverted back to intel's v18.20.0.9 (23/8/2015) - IMHO I think it's the most stable version so far.
    ( some ppl on the web think that v17.15.0.5 also makes a good revert choice - tested it, but it have many issues as well )
