Rampage VI Extreme Bluetooth Connectivity Issues
Skunkfoo
Has anyone been able to connect Bluetooth devices to their Rampage VI Extreme yet?
I have an 808 Bluetooth speaker and Apple Airpods headphones that connect to my Rampage IV Black with no issues (just add device and pair).
I tried the same on my new Rampage VI Extreme and all I get is "Add a device, Make sure your device is turned on..."
I'd like to know if I have to RMA the board or not before I start implementing the custom water loop.
9 REPLIES 9
broncogr
Have you installed the WiFi antenna?
Should be needed for Bluetooth connectivity
You are a life saver! Unless I missed it, I didn't see anywhere in the Mobo Manual that the antennas are needed for Bluetooth.
Yes I had no BT with antenna not connected and searched the manual and it was not mentioned. Works great now!:confused:
Guess I just don't understand the connection between BT and 802.11 wifi.
After 2 weeks my BT has stopped working. Had a keyboard, mouse and earphones all working and now none. Have tried everything including reloading drivers but nothing!!!!????:mad:
is the BT radio showing up in device manager. I’m using mine here and there for a mouse when my spatha battery dies because I forgot to put it in its cradle (shortest battery life of any mouse in history!!)
Here is a snip of my device manager.
I have since removed all drivers (including hidden) and reinstalled drivers (ASUS ones). Error is "BT hardware not found". I have both aerials attached.
68438
Reinstalled Windows and that got it working.
68438
What is that in the Bluetooth list? I don't have that MOMENTUM M2 thing. Is that some card you added? Perhaps that was messing your Bluetooth up.
Momentum is just a pair of Sennheiser Bluetooth headphones 😉 Got one myself.:D
Totaly did not see that comming. That you needed the installation of the WiFi antenna to get Bluetooth up and running.
But now my Sony works like a charm 😄
