Page 2 of 8 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 74
  1. #11
    ROG Guru: Yellow Belt Array xarot PC Specs
    xarot PC Specs
    Laptop (Model)Asus GL504GM
    MotherboardAsus Rampage VI Extreme
    Processori9-7980XE
    Memory (part number)Corsair Dominator Platinum 64GB CL16-18-18
    Graphics Card #1Palit RTX2080TI
    Sound CardIntegrated
    MonitorAsus PG279Q
    Storage #1Intel 750 1.2 TB PCIe
    Storage #2Samsung 960 Pro 1 TB
    CPU CoolerEK Supremacy EVO Full Nickel
    CasePhanteks Enthoo Primo
    Power SupplyCorsair AX1500i
    Keyboard Blackstorm Mech RGB
    Mouse Steelseries Rival 310
    Headset Sennheiser HD555
    Mouse Pad Razer Goliathus Extended
    OS Windows 10 x64
    xarot's Avatar
    Oct 2013
    44
    177
    @Raja@ASUS should I try filling in the bug report you have posted as sticky? I am thinking if this could be done since there are not many users with 7980XE and R6E, at least not yet. Or too early/hardware specific issue for that?
    Gaming: i9-7980XE H2O - Rampage VI Extreme - 64 GB Corsair Dominator Platinum DDR4-3200 - Palit RTX2080TI H2O - Phanteks Enthoo Primo - Corsair AX1500i - Intel 750 1.2 TB - Samsung 960 PRO 1 TB
    HTPC: i7-6950X - X99-M WS - 32 GB G.Skill RipjawsV DDR4-2400 - GTX1070 - Bitfenix Pandora - Corsair AX860 - Intel 750 400 GB + Samsung 1 TB 850 EVO
    All around: i7-9900X H2O - Rampage VI Extreme - 64 GB G.Skill 4000 CL18-19-19-39 - Strix RTX2060 - In Win 101C - Samsung 960 EVO 512 GB
  2. #12
    ROG Enthusiast Array Aysberg PC Specs
    Aysberg PC Specs
    MotherboardASUS ROG RAMPAGE VI EXTREME
    ProcessorIntel Core i9-7980XE
    Memory (part number)4 x F4-3200C14-16GTZ
    Graphics Card #1ASUS ROG STRIX GTX 1080 Ti GAMING OC
    Sound CardCreative SB Zx
    Monitor1x LG 34GK950G / 2 x HP DreamColor Z27x
    Storage #12 x Samsung NVMe 970 EVO 2TB / Samsung NVMe 3 x 960 EVO 1TB
    Storage #24 x SanDisk SDSSDHII960G
    CPU Coolercuplex kryos NEXT
    CaseLianLi PC-A75X
    Power SupplyCorsair HX1200i
    Keyboard Corsair K95 RGB
    Mouse Roccat KONE XTD Optical
    Headset AKG K712 + ModMic 5
    OS Windows 10 Pro x64 1809
    Network RouterMikroTik CRS317-1G-16S+RM
    Accessory #1 Mellanox ConnectX-3
    Accessory #2 Asus Hyper M.2 X16 Card
    Nov 2013
    18
    60
    I am running also a 7980XE + Rampage VI bios 0802 combo, OS (W10) is on a Samsung 960 EVO NVME plugged into the onboard M.2_1(Socket 3). Tested the system with 3200 CL 14 TridentZ modules and had freezes really often*, changed over to an older RipJaws Kit and it seemed stable but isn't. Had a freeze after 56% memtest.
    I am running everything on stock with optimized defaults and RAM clocked to 1066, so not even XMP.
    System just freezes where it was, screens stay on, no reboot, no bluscreen, just the desktop or whatever was running. I think the power light on my case turns off, while the HDD led is on permanently.
    Never had a faulty CPU and I had the idea the RVIE was delayed to fit the 7980XE first place.
    *during boot, entering desktop, in game, during memtest - no visible pattern load or idle.
  3. #13
    Tech Marketing Manager HQ Array Raja@ASUS's Avatar
    Apr 2011
    161
    7,454
    If it goes away when you increase memory related voltages (DRAM voltage and SA voltage), or relax memory timings, then it's memory instability. I'd try that at stock settings so you get some indication of where it's coming from. You can use fewer memory modules, relax memory timings, and try different voltages to see if that impacts it.
  4. #14
    xarot PC Specs
    Processori9-7980XE
    MonitorAsus PG279Q
    OS Windows 10 x64
    xarot's Avatar
    Oct 2013
    44
    177
    I ran GSAT for 1 hour today with the RAM kit I use with my 7900X at stock settings on R6E without errors. On 7980XE I cannot even start GSAT before it freezes. I already tried 1.0 V VCCSA, it doesn't go even that high with XMP and relaxed tRFC, but I'll try to loosen the primary timings and increase DRAM voltage.
    I guess I'll open a local ticket to ASUS too.
    EDIT:
    I input the settings that were suggested to another issue here: http://www.overclock.net/t/1637027/a...#post_26395928
    After this, I was able to run Prime95 28.5 for one hour and then I stopped it. I tried GSAT but the process ceased to do anything, but the OS worked normally. So it seems it is related to BIOS issues.
    When can we expect a new BIOS to fix to this issue?
  5. #15
    Apr 2011
    161
    7,454
    Quote Originally Posted by rzotti View Post
    I have the exact same issue happening here - but on the I9-7900. Random freezes on windows and even on the bios screen when at safe settings. Changing CPU options does not helped. This got much better after changing the dram timings / voltage to manufacturer suggested settings - 19/19/19/39 with 1.4V. I still get random freezes though, usually after days with the computer on without any issue. Not sure yet the cause but guessing it continues being memory. Possibly because I am running two (same SKU/manufacturer) 16gb kits to get to 32gb of memory, on a quad channel config. Tried to increase DRAM voltage but has not helped. Will try to increase the timings next to see if it gets better. If it is not memory, then things will get really complex.
    Try a single kit. Need the full part number of the kit, and also the full system config - everything you have plugged in.
  6. #16
    Apr 2011
    161
    7,454
    Quote Originally Posted by xarot View Post
    EDIT:
    No ETA yet. Have fed all details back. HQ will do the rest.
  7. #17
    xarot PC Specs
    Processori9-7980XE
    MonitorAsus PG279Q
    OS Windows 10 x64
    xarot's Avatar
    Oct 2013
    44
    177
    Quote Originally Posted by Raja@ASUS View Post
    Thanks, great to hear HQ is looking into it.
  8. #18
    Apr 2011
    161
    7,454
    Drop me a PM. Have something for you to test.
  9. #19
    Aysberg PC Specs
    CaseLianLi PC-A75X
    Nov 2013
    18
    60
    Did a memtest run over night, with 1.25v instead of the 1.20v and the system was running for 6 hours. I think this is more or less stable.
    Anyway, I am only running 2 modules out of four and a MB should be stable on defaults without any tweaking
    PS Did another run with default voltages and changed the settings you suggested for VROC (DRAM timing section>IO Control Pre-Emphasis) and the system seems stable too.
    Have no 4x16GB kit at the moment, so I cannot say if this will work in my final everyday setup.
  10. #20
    ROG Member Array rzotti PC Specs
    rzotti PC Specs
    MotherboardASUS Rampage VI Extreme
    ProcessorIntel I9 7900x @ 4.6GHZ (dellided/binned)
    Memory (part number)2 x16GB G.Skill DDR4 TridentZ RGB 4266Mhz PC4-34100 CL19 1.4V Dual Channel Kit (2x8GB)
    Graphics Card #1ASUS GEFORCE STRIX 1080 TI OC
    Graphics Card #2ASUS GEFORCE STRIX 1080 TI OC
    MonitorSAMSUNG 29" ULTRAWIDE MONITOR S29E790C
    Storage #1SAMSUNG 960 PRO x3 (2 in raid 0, 1 for boot)
    Storage #2WD BLACK 6TB
    CPU CoolerEKWB CUSTOM COOLING
    CasePHANTEKS ELITE
    Power SupplyEVGA 1600W
    Keyboard CORSAIR GAMING K95 RGB PLATINUM
    Mouse LOGITECH G903 WIRELESS GAMING MOUSE
    OS Windows 10 Pro 64-Bit
    Aug 2017
    18
    Thank you Raja ! Any help you can give is most welcomed.
    Memory Kit: F4-4266C19D-16GTZR - DDR4-4266 PC-34100 8mbx2 - CL 19-19-19-39 1.4V
    Rampage VI extreme with:
    Intel I9 7900x (delidded) , cooled with a Kraken x62
    2 kits of the aforementioned memory (total 32gb)
    2 samsungs 960 Pro 1tb in the DIMM2 with EKWB heatsinks (DIMM2@CPU, running in software raid)
    1 samsung 960 pro 512gb in the M2 slot under the cover.
    2 Asus Strix 1080 TI OC on SLI
    1 HDD WD Black 6tb
    Phanteks Elite - case LED connected to the board.
    Power Supply - EVGA 1600W Supernova T2
    ISSUE: at safe settings, computer freezes constantly and frequently, at random times, even in BIOS. At optimized settings , it works for days on - but ultimately freezes randomly too.
