Results 1 to 4 of 4
    New ROGer Array SWster PC Specs
    SWster PC Specs
    MotherboardROG CROSSHAIR VI HERO
    ProcessorRYZEN 1700X
    Memory (part number)32 GB DDR4
    Graphics Card #1ROG STRIX 1080 TI
    Storage #1GOODRAM Iridium PRO 240 GB
    Storage #2HYPERX SAVAGE 240 GB
    CPU CoolerFractal Design Celsius S24
    CaseCorsair Crystal 570X
    Power SupplyEVGA SuperNova 850 W G2
    Keyboard Razer BlackWidow 2014
    Mouse Razer Taipan
    Headset HyperX Cloud 2
    Mouse Pad Razer Goliathus Speed
    OS Windows 10 Pro x64
    Sep 2017
    2
    Question Vengeance RGB 3000 Overclock 4x8. Help.
    Yo guys. Just a day ago got my crosshair 6 and ryzen 1700x. Got stable 4.0 ghz on cpu. but can't OC memory
    Here is my memory:
    VENGEANCE® RGB 32GB (4 x 8GB) DDR4 DRAM 3000MHz C15 Memory Kit (CMR32GX4M4C3000C15) SINGLE RANK
    Any advice how I can OC it for the stable result?
    All lifetime was on intel cpu's
    ROG Guru: Green Belt Array skellattarr PC Specs
    MotherboardCrosshair viii hero
    ProcessorRyzen 9 3950x
    Memory (part number)G.SKILL Trident Z RGB 64GB 4X16 3200MHZ
    Graphics Card #1MSI Ventus x3 oc 3080
    Sound Cardcreative sound blaster ae-5
    Monitoracer 28inch 4k
    Storage #1sabrent gen 4 2tb, Samsung 960 evo 1tb
    Storage #23x 3tb hhd/segate 10TB drive, segate 16TB drive
    CPU CoolerNZXT Kraken Z73 water cooler
    CaseThermaltake veiw 71 case
    Power Supplycorsair 1200w
    Keyboard Corsair k95 rgb
    Mouse corsair m65 pro rgb
    Mouse Pad corsair mm800 rgb polaris
    Headset/Speakers logitech 5.1
    OS windows 11 pro
    skellattarr's Avatar
    Feb 2012
    20
    671
    I have that memory it will only overclock to 2800 on bios 9920 or 1401 the newer bios won't overclock
    amd ryzen 9 3950x
    CROSSHAIR Viii hero
    Corsair Hydro Series H115i
    G.SKILL Trident Z 3200mhz 64gb 4x16 timings 16,18,18,38
    asus rog strix gtx 1080
    TOSHIBA 3TB hdd 3x a total of 9tb, 10 tb hdd and a 1tb mushkin ssd
    corsair axi 1200i 1200 watt psu
    thermal take view 71 case
    SWster PC Specs
    Mouse Razer Taipan
    Sep 2017
    2
    Unhappy
    Quote Originally Posted by skellattarr View Post
    I'm running at Bios version 1701 2017/10/03. It's a Hynix, I've set DRAM for 1.4V and basic timings to reach 2993 (15 17 17 35 52) Computer works fine till stress test. I use TM5. Tried to increate timings, no luck.
    ps. BCLK is set to 100. Maybe I should shake this a little bit huh?
    OS windows 11 pro
    Feb 2012
    20
    671
    try bios 9920 you will have better luck
    amd ryzen 9 3950x
    CROSSHAIR Viii hero
Tags for this Thread
