10-18-2017 02:19 PM - last edited on 03-05-2024 09:51 PM by ROGBot
10-18-2017 02:44 PM
10-18-2017 02:55 PM
10-18-2017 02:56 PM
10-18-2017 03:10 PM
Chudik wrote:
Thank you for the information , i will try to mod this. But at the end is OC with P state bather then conventional OC with CPU Core ratio?
Korth wrote:
I don't know P State overclocking, I know oscillators, lol.
10-18-2017 03:45 PM
unknownmiscreant wrote:
Not really TBH. I have p-state setup as I was curious and didn't want the CPU idling at 4GHz, 1.42v all day everyday, but it makes almost 0 difference to power consumption. If you have it setup, leave use it, but I wouldn't waste your time setting it up, unless your curious.
Heres a video about it: https://www.youtube.com/watch?v=bzxn1hS7Nq4
It only talks about power consumption, so I doubt it is the whole story, as I presume there is a CPU takes time to boost aspect as well, but have never looked into it. My system feels pretty snappy and responsive, so I'm happy.
As for the BCLK issue, I just override mine to 100MHz, although with multiplier 40 (A0 p-state FID) I get 3.997GHz under load, as the BCLK dips to 99.9-99.7MHz. Its really a non-issue.
10-18-2017 04:08 PM
Chudik wrote:
Yes i so that Video , i'm not really worry about power but more for cooling , and i have 2 different configs saved on Bios one for 4.00GHz with P state , that i'm using and i links pix and its super stable , and one config with CPU core ration OC and BCLK... and its stable to. performance seems to be the same.
I'm sorry about thous stupid questions i'm new to all OC and AMD etc...
So i change the OC to core ration OC and BCLK..." and now i'm getting same stooped info from Task Manager .. my OCD is Kiling me now haha
[Removed pictures]
I'm losing it
10-18-2017 04:12 PM
10-18-2017 04:25 PM
Chudik wrote:
Got it !!!!
Thank you Guys for a great help!
I will stay with P State for now and use bather tools then windows taks manager haha 🙂
10-20-2017 08:55 AM
