Results 1 to 1 of 1
    New ROGer Array
    Nov 2016
    1
    Question Replacment GPU Fan for G30AB
    I have a friend's ROG system, and the fan on the GPU failed and is now overheating. I'm looking to find a replacement.
    The system itself is a G30AB-CA005S system, and has a GTX660 GPU in it (M/N GTX660-3GD5-2DIS-DP).
    I was looking at something like this: https://www.newegg.ca/Product/Produc...-053-_-Product
    However, I have no clue if the mounting holes are compatible.
    Any help would be appreciated.
