Results 1 to 9 of 9
    ROG Guru: Yellow Belt Array The F34R Channel PC Specs
    MotherboardAsus Maximus VIII Hero Z170
    ProcessorIntel Core i5-6600K
    Memory (part number)Corsair CMK16GX4M2B3000C15
    Graphics Card #1Asus GTX 1080 Strix
    MonitorAcer XB270HU 144Hz G-Sync
    Storage #1Crucial MX200 500 GB
    Storage #2Seagate 2TB SATA HDD
    CPU CoolerCorsair H105 (push)
    CaseCorsair 760T
    Power SupplyEVGA SuperNOVA 850 P2
    Keyboard Corsair K70 RGB
    Mouse Mionix Avior 8200
    OS Windows 10 Pro x64 (UEFI)
    Nov 2015
    196
    M10H: rear I/O USB 3.1 gen2 (red) port not working
    Can't get it to recognise a USB drive. Driver is installed (a Microsoft driver apparently although I installed all drivers from the Asus website) so no idea what's happening.
    Asus Z370 Maximus X Hero | Intel Core i7-8700K 4.7GHz | Corsair H105 | G.Skill Trident Z 3333MHz CL16 16GB | Asus GTX 1080 Strix | EVGA SuperNOVA 850 P2 | Crucial MX200 500 GB | 760T | Acer XB270HU 1440p | Windows 10 Pro x64
    ROG Enthusiast Array
    Dec 2016
    34
    Shor OVERLAND
    Do you get any sort of notification or sounds when you insert a drive or tried multiple devices? Also is it enabled in your BIOS?
    You can try and right click and update both of those drivers to see if that helps. I am using the latest ASMedia USB 3.1s driverset for both of those entries (1.16.49.1) Looks like your driver is the generic one included with Windows, though that usually doesn't cause any issue.
    CaseCorsair 760T
    Nov 2015
    196
    Quote Originally Posted by NeoandGeo View Post
    In order of your asking: no, no, no (drive worked fine in other ports), have to check (didn't touch it in the BIOS).
    Where did you find that Asmedia driver? Could you link it pretty please? Not on the Asus website for me. After installing all Asus website drivers there 2 devices left without a driver (PCI host controller and something else I forgot) that Windows update took care off - *shudder*
    Dec 2016
    34
    I use the Win-Raid forums to find the latest updated driver packages for USB/MEI/AHCI etc. drivers. The thread for updated USB 3.0 / 3.1 driver packages from ASMedia is located here:
    http://www.win-raid.com/t834f25-USB-...nd-modded.html
    CaseCorsair 760T
    Nov 2015
    196
    Thank you so much!
    Dec 2016
    34
    No problem. Hopefully that solves your issue. Let us know if it works.
  7. #7
    CaseCorsair 760T
    Nov 2015
    196
    Worked like a charm! Thanks so much!!
  8. #8
    Dec 2016
    34
    Awesome. That forum is great at helping you keep up to date with the drivers for system components that are either not updated frequently or not provided at all by the motherboard manufacturer.
    A side effect of keeping the newest drivers installed is Windows will be less likely to force an update that breaks functionality without warning.
  9. #9
    CaseCorsair 760T
    Nov 2015
    196
    I've disabled Windows update drivers again (every build update enables it again, gosh I despise Microsoft).
