Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
    New ROGer Array amino1990 PC Specs
    amino1990 PC Specs
    MotherboardAsus ROG Strix Z270E Gaming
    ProcessorIntel Core i7-7700K
    Memory (part number)Corsair 2x8GB Vengeance LPX DDR4-3000
    Graphics Card #1Gigabyte GeForce GTX 1080 Windforce 8GB
    Graphics Card #2Gigabyte GeForce GTX 1080 Windforce 8GB
    MonitorAcer Predator XB271HK bmiprz
    CPU CoolerCorsair Hydro H100i v2 Liquid Cooler
    CaseThermaltake View 31 RGB Tempered Glass
    Power SupplyEVGA Supernova 850 G3
    Oct 2017
    11
    Unhappy high temperature when overclocking
    Recently, I built my first computer and tried to overclock using this tutorial :https://rog.asus.com/articles/guides...locking-guide/ I don't really understand it, but I can adjust the vcore and the multiplier to get 4.7 gHz with vcore =1.24 V. My computer can pass a 4 hours realbench while all the cores reach ~80 C (max temp =85 C). For me, this temperature is very high, and if I overclock ram with xmp profile, the temperature can even reach 88-90 C. How can I reduce the temperature? I don't know whether my cooling system has problem, or temperature drop can be only archived with better cooling system.
    Nate152 PC Specs
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba OCZ VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Mouse Razer Basilisk
    OS Windows 10 Home 64 bit
    Nate152's Avatar
    Feb 2013
    308
    16,359
    Hi amino1990
    The 7700k is known to run hot but I'd expect a little better temperatures with the H100i, there are a few things that can lead to higher temps. The best thing you can do is delid, it will reduce temps on average 15c.
    1) What is your room temp ?
    2) Did you use the pre-applied thermal compound or apply your own ?
    3) Not enough thermal paste or applied unevenly
    4) Waterblock not making good contact with the cpu
    5) Faulty cpu cooler
    Here are temps and voltage with my 7700k delidded, the Vcore is the cpu voltage.
    Banned Array JustinThyme PC Specs
    Laptop (Model)G752VY-DH72
    MotherboardRampage VI Extreme
    ProcessorI9 9940X
    Memory (part number)64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17
    Graphics Card #1ASUS Strix 2080Ti O11G @ 2.1GHz
    Graphics Card #2ASUS Strix 2080Ti O11G @ 2.1Ghz
    Graphics Card #3ROG Nvlink
    Graphics Card #4Have to feed animals
    Sound CardExternal Audioengine D1 24 bit 192kbps DAC
    MonitorASUS PG348Q @ 100Hz
    Storage #1Intel 905P 480GB U2 flavor
    Storage #2Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1
    CPU CoolerHeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS
    CasePhanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM
    Power SupplyCorsair AX 1500i
    Keyboard ASUS Claymore
    Mouse ASUS Spatha, Logitech MX Master
    Headset Sennheiser HD 700
    Mouse Pad ASUS ROG Sheath
    Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub
    OS Win10 Pro 1809
    Network RouterNetGear NightHawk X10
    Accessory #1 NetGear Prosafe 10GBe Switch
    Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
    Nov 2013
    144
    3,858
    Quote Originally Posted by amino1990 View Post
    The 7700K is known to run hot when overclocking. Intel played a cruel joke by using toothpaste between the die and the IHS. If you want to get a decent OC you are going to have to do the delid process. You can either do it yourself or send it off to Silicon lottery and they will do it for a fee and test it to see what OC your chip is capable of.
    I delidded mine and replaced the crappy TIM with cool labs liquid ultra and the temps dropped 20C. This is not to be taken lightly as this is metal TIM and easy to botch and it will 100% void your warranty.
    amino1990 PC Specs
    Oct 2017
    11
    I applied my thermal paste (kryonaut thermal grizzly) but the temperature was still high. I think my room temperature is ~20 C. If I delid my CPU, do I need to replace the liquid metal over time?
    ProcessorI9 9940X
    OS Win10 Pro 1809
    Nov 2013
    144
    3,858
    The liquid metal TIM hasn’t been on the market all that long but so far there is no indication it breaks down and needs to be replaced.
    20C is more than fine for an ambient.
    You can apply all the TIM you want 20 ways from Sunday and it won’t change anything. Pulling heat off the IHS is pointless if the IHS isn’t pulling the heat off the die. **
    amino1990 PC Specs
    Oct 2017
    11
    Yesterday I delided my CPU and the temperature decreases dramatically. Using the guide I mentioned in the first post, I set the multiplier = 49, VCPU = 1.3 and tried a short stress test (15 mins with REALBENCH). The temperature is ~ 70 C. However, I got BSOD (< 15 mins with Realbench) when I increased the frequency from 4.5 to 5 GHz even if the VCPU is increased to 1.32 V. Is that the limit of my CPU? If I want to manually overclock Ram, which parameters should I change? I read some guides but I don't really understand how to do this step.
  7. #7
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,359
    Hi amino1990
    Awesome on delidding, it was well worth it huh?
    The BSOD means you need more VCPU, since your temps are very good you have some headroom.
    Before raising the voltage, set LLC to level 5 or 6 and VCPU to 1.32v and run the test, if it stll BSOD's....
    Increase the VCPU .01v and test each time, next would be 1.33v and if it BSOD's, try 1.34v. You shouldn't need up to 1.40v but it's safe if temps allow. Don't let temps go past 90c.
    Let us know what voltage got you stable and what temps are too.
    I think I see 5.0GHz coming.
  8. #8
    amino1990 PC Specs
    Oct 2017
    11
    I'm glad that I didn't break my CPU.
    I set LLC to 5, VCPU =1.32, multiplier = 50 can pass the 4 hour tress test with the max temp ~83 C. Is that ok? I tried lower VCPUs but always got BSOD at some point during stress test. What should I do to overclock Ram?
  9. #9
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,359
    Yeah that's ok but temps seem a little high, was the voltage at 1.32v or close to it while running the test ?
    To set your ram enable XMP or set your ram manually.
  10. #10
    amino1990 PC Specs
    Oct 2017
    11
    I want to manually overclock Ram, but which parameters should I adjust? Using HWINFO64, I found that the VCORE is 1.312, and the maximum VCORE is 1.328 when I run stress test.
