GL752VW Problems and Event Viewer
AGenericUsernam
Hello, i have a ROG GL752VW and 4 days ago i lost power while gaming. I was on battery. After power up the battery had 35% left.
And after i looked through event viewer i found a ton of these logs popping up every minute:
A corrected hardware error has occurred.
Component: PCI Express Root Port
Error Source: Advanced Error Reporting (PCI Express)
Bus:Device:Function: 0x0:0x1C:0x3
Vendor ID:Device ID: 0x8086:0xA113
Class Code: 0x30400
The details view of this entry contains further information.
Event Xml:
[HTML]
17
0
3
0
0
0x8000000000000000
257970
System
DESKTOP-A58E3IQ
4
{00000000-0000-0000-0000-000000000000}
0xdf
4
0x101
0x10
0x407
0x0
0x1c
0x3
0x0
0x0
0x0
0x8086
0xa113
0x30400
0x0
0x0
0x0
0x0
0x1000
00000000000000000000000000000000
672
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
[/HTML]
AGenericUsernam
The event now pops every 30 seconds.
Falcon2_ROG
Customer Service Agent
Because we can not make sure what's happening of your laptop, we might suggest you to reinstall the OS and try again. Please back up your data to an external storage device , then using system restore function to reinstall the system. Sorry for the trouble.
Thank you for your reply.
