Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    New ROGer Array pixelwerk PC Specs
    pixelwerk PC Specs
    MotherboardASUS ROG Zenith Extreme X399
    ProcessorAMD 1950x THREADRIPPER
    Memory (part number)GSKILL 64 GB 3200 Mhz
    Graphics Card #1nVIDIA GTX1080ti
    Graphics Card #2nVIDIA GTX1080ti
    Graphics Card #3nVIDIA GTX1080ti
    Graphics Card #4nVIDIA GTX1080ti
    CPU CoolerENERMAX LiqTech TR4
    CaseLianLi PC-V1000lb
    Power SupplyEVGA 1600 G+
    OS Windows 10 PRO
    Oct 2017
    7
    When is an overclocked system considered as "running stable"
    I've overclocked my Threadripper 1950x system to 4.0 Ghz @ 1.351 volts and the system is running "solid". With max. temperatures of 75°C under full load for several hours.
    Even though it can happen that I end up having a bluescreen when rendering several hours with 100% CPU-load. Today it was a bluescreen after 8 hours but I also had the system rendering for 50 hours on 100% CPU load without a crash.
    Is this something I have to live with, when having an overclocked system, or is this already a sign, that the overclocking is beyond a stable point?
    ROG Guru: Black Belt Array Korth PC Specs
    Korth PC Specs
    MotherboardASUS X99 R5E (BIOS2101/1902)
    ProcessorHaswell-EP E5-1680-3 SR20H/R2 (4.4GHz)
    Memory (part number)Vengeance LPX 4x8GB SS DDR4-3000 (CMK32GX4M4C3000C15)
    Graphics Card #1NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Graphics Card #2NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Sound CardJDS Labs O2+ODAC (RevB), USB2 UAC1
    MonitorASUS PG278Q
    Storage #1Samsung 850 PRO 512GB SSDs, 4xSATA3 RAID0
    Storage #2Comay BladeDrive E28 3200GB SSD, 8xPCIe2
    CPU CoolerRaijintek NEMESIS/TISIS, AS5, 2xNH-A14
    CaseObsidian 750D (original), 6xNH-A14
    Power SupplyZalman/FSP ZM1250 Platinum
    Headset Pilot P51 PTT *modded*
    OS Arch, Gentoo, Win7x64, Win10x64
    Network RouterActiontec T3200M VDSL2 Gateway
    Accessory #1 TP-Link AC1900 Archer T9E, 1xPCIe
    Accessory #2 ASUS/Infineon SLB9635 TPM (TT1.2/FW3.19)
    Accessory #3 ASUS OC Panel I (FW0501)
    Korth's Avatar
    Mar 2015
    152
    2,719
    My work machines are "mission critical", configured to sustain three or four "nines" of uptime, built with as much "server grade" reliability and redundancy as possible. So these machines use ASUS boards and Titanium PSUs and enterprise-class SSDs and quality UPS backups and a robust isolation transformer, with ECC memories and self-powered data caches wherever they're supported. I consider overclocks "stable" on these machines when they can run brutal stress/torture tests for a full week (168 hours), uninterrupted, unsupervised, in a nasty "worst case" 30C to 35C ambient. (Although I do check their status a few times each day, just to confirm they're not crashed or catching on fire, to not waste more time on already failed test burns, but I don't really have to do so. Data corruption is absolutely intolerable, data integrity is highest priority. Downtime is somewhat intolerable, lost uptime equals forced downtime which I'd rather spend doing useful work than spending on troubleshooting/tinkering a failed platform. Yes, it means the overclocks are more marginal/modest and less reckless/spectacular.)
    My overclocked gaming machines only need to stress for a few hours, I usually just run them overnight. The logic is that I'm only going to actually demand full performance across the entire duration of a long gaming session (a few hours at a time, at most). A BSoD/crash/lock/reboot or other fault which appears only rarely and only becomes evident after days of relentless punishment is of little concern, especially since whatever data's on the machine isn't "critical" and it can all be restored/rebooted to working order quick enough. So I punch up the overclocks towards the maximums the machines can sustain, turning them down a notch only if crashes/etc become annoying. An important part of this "maximum overclock" approach is rigid adherence to a solid backup strategy.
    So it's a personal judgement call. From what I've read online, most gamers/overclockers seem to consider one hour or a few hours sufficient, even ten to twenty minutes is enough to weed out the overwhelming majority of unstable overclocks. It's also not as simple as measuring a definite "pass/fail" threshold, each part has a blurry zone where a decision needs to be made about how far up the curve of performance vs temps/volts/stability/longevity you want to go, the more you shift the balance to parameter(s) on one side the more sacrifice to parameter(s) on the opposite side. Again, it's a personal judgement call.
    [/Korth]
    Banned Array JustinThyme PC Specs
    Laptop (Model)G752VY-DH72
    MotherboardRampage VI Extreme
    ProcessorI9 9940X
    Memory (part number)64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17
    Graphics Card #1ASUS Strix 2080Ti O11G @ 2.1GHz
    Graphics Card #2ASUS Strix 2080Ti O11G @ 2.1Ghz
    Graphics Card #3ROG Nvlink
    Graphics Card #4Have to feed animals
    Sound CardExternal Audioengine D1 24 bit 192kbps DAC
    MonitorASUS PG348Q @ 100Hz
    Storage #1Intel 905P 480GB U2 flavor
    Storage #2Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1
    CPU CoolerHeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS
    CasePhanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM
    Power SupplyCorsair AX 1500i
    Keyboard ASUS Claymore
    Mouse ASUS Spatha, Logitech MX Master
    Headset Sennheiser HD 700
    Mouse Pad ASUS ROG Sheath
    Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub
    OS Win10 Pro 1809
    Network RouterNetGear NightHawk X10
    Accessory #1 NetGear Prosafe 10GBe Switch
    Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
    Nov 2013
    144
    3,858
    Crash=not stable
    Now lets talk real world. Are you using it with a 100% load for several hours? What are you using to create that load for several hours? Please dont tell me prime95.......prime95=CPU space heater and in no way reflects any real world scenarios. If you want to use it for short duration's to test you cooling capabilities great. Othe than that use something like 3Dmarks, Heaven, Real Bench etc.
    pixelwerk PC Specs
    OS Windows 10 PRO
    Oct 2017
    7
    I'm usually running Multi-XEON machines here, so this is my first system that I've overclocked and I have no reference values therefore I was asking. Thanks for your input. The system is planned for everyday usage and not server-tasks. For rendering-tasks I'll still rely on my inhouse renderfarm, so I don't think it'll run for several hours full load. The test I've run were just for stresstesting the system and tweaking the fans. The extra overclocking-Mhz come in quite handy in single-threaded tasks, one of the reasons why I decided to go for a Threadripper-system instead of another Dual XEON system or maybe a dual EPYC-system.
    So do you think I can keep the system on this clockspeed or do you think I should better set it back to stock-speed?
    pixelwerk PC Specs
    OS Windows 10 PRO
    Oct 2017
    7
    Quote Originally Posted by JustinThyme View Post
    Crash=not stable
    Rendering animations and highres stills with V-Ray, the purpose of the workstation. I was also running some synthethic benchmarks, but most of the testing I was doing realworld-scenarios
    Korth PC Specs
    MonitorASUS PG278Q
    Korth's Avatar
    Mar 2015
    152
    2,719
    Backup your data frequently and run your rendering tasks ... if the machines (or their overclocks) prove unstable then upgrade (or turn things down a notch) and repeat.
    There's no need to obsess over exact failure thresholds, only a need to demonstrate that normal usage doesn't exceed them. Little sense in spending more time testing the machines than would be needed to recover from failures.
    [/Korth]
  7. #7
    pixelwerk PC Specs
    OS Windows 10 PRO
    Oct 2017
    7
    Brunssum mineria
    My backup is pretty bulletproof with an external RAID and even LTO-tape drive backup and no projects are stored on the workstation locally, so even if the workstation would literally burn down to the ground, nothing is lost...datawise.
    Thanks a lot for your feedback
  8. #8
    ProcessorI9 9940X
    OS Win10 Pro 1809
    Nov 2013
    144
    3,858
    Quote Originally Posted by pixelwerk View Post
    Which real world scenarios?
  9. #9
    ROG Guru: Blue Belt Array jab383 PC Specs
    jab383 PC Specs
    Motherboard24/7 rig : Maximus VI Extreme
    Processori7 4790K
    Memory (part number)16GB Mushkin Redline 2400 10-12-12-28 + 16GB Corsair Vengeance 2400 10-12-12-31
    Graphics Card #1AMD Firepro W5000
    Sound CardM6E Supreme FX
    MonitorDell U2413
    Storage #1Kingston SH103S3240G SSD
    Storage #2Seagate ST1000DM003 1TB
    CPU CoolerCustom water loop, Delidded, Liquid Metal TIM
    CaseCoolerMaster HAF XM
    Power SupplyCorsair HX-750
    Keyboard Logitech G710+
    Mouse Logitech M705
    OS Windows 7 64 Pro
    jab383's Avatar
    Feb 2014
    107
    848
    The basic question - What is the criterion for stability. In my opinion, it's stable unless it isn't. For my competitive overclocking, it's stable if it runs the benchmark and different benchmarks need different settings. Of course, that's not what you're doing.
    For serious work, and for gaming, on my 24/7 rig I've had to extrapolate from synthetic benchmarks to the real world. "Real world" testing such as with ROG Realbench didn't quite work. The PC crashed at an intense transition in Creative Suite after passing Realbench for hours. Real stability required a more stringent test. I also dislike toasting CPUs for hours at even moderate overclocks. They degrade quickly enough without any Prime95 torture. Stability testing takes minutes if the right tests are used.
    I use OCCT - the large data set test - for 5 minutes. That has been enough to show stability in integer processing. For AVX instruction stability, i use y-Cruncher
    http://www.numberworld.org/y-cruncher/
    Each run of Pi for 1 billion digits takes about 6 minutes divided by the number of cores. Two or three runs are enough to show stability. y-Cruncher is also memory intensive, so it's a good indication of stable memory if that's what you're overclocking. No profile that passes those two tests has ever crashed on me.
  10. #10
    pixelwerk PC Specs
    OS Windows 10 PRO
    Oct 2017
    7
    Real world scenario for me means the things I'm using on a daily base. Simulating, raytracing, compositing and video editing
Tags for this Thread
