Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 24
    ROG Guru: Yellow Belt Array Carbonicdk PC Specs
    Carbonicdk PC Specs
    MotherboardAsus ROG Strix Z370-E Gaming
    ProcessorIntel i7-8700k
    Memory (part number)F4-3600C16Q-32GTZR
    Graphics Card #1Asus ROG STRIX GTX1080TI O11G GAMING
    Sound CardSchiit Modi 2 Uber
    MonitorAsus MG278Q
    Storage #1Samsung 960Evo
    CaseFractal Design Define R6 - Tempered Glass
    Power SupplyCorsair Professional Platinum Series AX860
    OS Windows 10 64bit
    Mar 2016
    143
    New Z370 system unstable memory and AURA issues
    On my Z370-E I have a 32GB kit: F4-3600c16q-32gtzr
    I however can't get them to run stable at their rated 3600mhz frequency. So far I've tried enabling XMP (no CPU overclocking to get the memory running first) and lowering the frequency to 3400mhz. The memory is working fine at these speeds in Z170 systems including the Maximus Ranger VIII.
    Any ideas about what to tweak? Should I increase the voltage over the XMP 1.32??
    As for the onboard RGB in the IO shroud, Aura cannot see it. Is this a Fall Creators issue?
    untouched Array Praz's Avatar
    Apr 2011
    137
    4,038
    Quote Originally Posted by Carbonicdk View Post
    Hello
    Set the memory voltage to the spec'd 1.35V.
    Carbonicdk PC Specs
    MonitorAsus MG278Q
    OS Windows 10 64bit
    Mar 2016
    143
    Quote Originally Posted by Praz View Post
    Hello
    Oh, sorry, that's what I ment.
    Am now trying 3200mhz to see if the board can run that stable as 3400mhz didn't work.
    Lastly, added a RBG lightning strip to my build. That also doesn't work. From reading on other threads it seems Aura was not properly tested with Win10 Fall Creators Update before it released.
    New ROGer Array loriel PC Specs
    loriel PC Specs
    MotherboardStrix Z370-E
    ProcessorIntel 8700k
    Memory (part number)G.Skill F4-4000C18D-16GTZR
    Graphics Card #1Gigabyte GTX1070 G1 Gaming
    Storage #1Samsung 960evo
    Storage #2Samsung 850evo
    CPU CoolerCorsair H100iv2
    CaseCM Mastercase pro 5
    Power SupplySeasonic Platinum Series 860w
    OS Windows 10
    Oct 2017
    2
    My conf
    I don't know if that helps but these are voltages i manually set to run 3600mhz
    This is with 4000 CL18 kit toned down to 3600 CL16 specs.
    F4-4000C18D-16GTZR
    Carbonicdk PC Specs
    MonitorAsus MG278Q
    OS Windows 10 64bit
    Mar 2016
    143
    So, I tried upping the CPU VCCIO and System Agent Voltage as you suggested and even up to 1.25. Still don't even boot. Guess I'm stuck at <3000mhz until Asus makes their bios more memoryfriendly or find the magic settings.
    loriel PC Specs
    OS Windows 10
    Oct 2017
    2
    I really hope it was 1.125 not 1.25 going too high can cause also issues.
  7. #7
    Carbonicdk PC Specs
    MonitorAsus MG278Q
    OS Windows 10 64bit
    Mar 2016
    143
    I tried 1.0, 1.125 and 1.25. None were successful.
  8. #8
    Carbonicdk PC Specs
    MonitorAsus MG278Q
    OS Windows 10 64bit
    Mar 2016
    143
    ROG STRIX Z370-E GAMING BIOS 0420 is now out and this has not improved memory stability.
  9. #9
    New ROGer Array
    Oct 2017
    1
    Z370-e aura issue still
    Anyone still having issues with aura mien went from asIo.sys to now failed to install and pop up with a webpage about a error report?
    Anyone know any fixes asus said to send back for rma but I feel as if it just a program fault*
  10. #10
    Carbonicdk PC Specs
    MonitorAsus MG278Q
    OS Windows 10 64bit
    Mar 2016
    143
    Quote Originally Posted by Eightyfiggs View Post
    I managed fix my Aura problems by reinstalling it a couple of times. Don't ask me why that should be necessary.
    Only the memory stability issues left.
