Results 1 to 5 of 5
    ROG Enthusiast Array
    Sep 2013
    8
    29
    Unhappy G752VY one of Usb port suddenly works only for 3.0 usb and does not work for 2.0 usb
    Hello,
    i have windows 10 64 , suddenly one of four usb ports started to work only with USB 3.0 , when i plug USB 2.0 device i only get power but no data at all , i tried installing USB drivers again and again but nothing happened , i also installed Kali live CD to see if it works there but nothing worked , i would appreciate if anyone can help me .
    Thanks
    ROG Guru: Gold Belt Array Clintlgm PC Specs
    Clintlgm PC Specs
    Laptop (Model)Asus G752VY DH72
    MotherboardAsus Z97 Pro WiFi and /Z97 Pro A
    ProcessorI7 4790K
    Storage #1512 GB M.2 Samsung 960 Pro
    Storage #21 TB Samsun 850 Pro
    CaseCool Master Haf
    OS Win 8.1 Pro and Win 10 Pro
    Clintlgm's Avatar
    Jul 2012
    105
    4,108
    try a different cable? otherwise you might have a damages pins in the socket
    G752VY-DH72 Win 10 Pro
    980m GTX 4 GB
    32GB DDR 4 Standard RAM
    Z97 PRO WiFi I7 4790K
    Windows 10 Pro
    Z97 -A
    Windows 10 Pro
    Sep 2013
    8
    29
    Quote Originally Posted by Clintlgm View Post
    Thanks for your reply , i tried different cables and USB Drives , only works for USB 3.0 , also i checked the socket and it was intact , nothing seems weird .
    Is this a common problem .
    Thanks
    Clintlgm PC Specs
    ProcessorI7 4790K
    CaseCool Master Haf
    Clintlgm's Avatar
    Jul 2012
    105
    4,108
    No not at all, usually the other way around. Basicly USB 2.0 has 5 connectors, USB 3.0 have 8 connectors they old type 1 plugs you notice only have connectors on one side of the plug. While USB 3.0 will have 4 on the up side and 4 on the down side. some of th newer plugs have these side by side. The controllers select either usb 3 or usb 2 by how many connections are made. the plugs are just that mechanical connectors for this to happen to just 1 port you pretty much have to have a disconnect of one or more of the 4 lead that are USB 2.0.
    There may be some other technological reason for this to happen beyond my expertise? I remember when we have shadow devices remaining connected to our USB 1 ports that would cause issues but I think that has gone away with modern OS they way IRQ are handled now days?
    980m GTX 4 GB
    Windows 10 Pro
    Z97 -A
    Windows 10 Pro
    Sep 2013
    8
    29
    Thanks for your answer , it was really helpful as i understood what is going on with this port .
    Thanks for your help
