Results 1 to 2 of 2
    ROG Member Array
    Oct 2017
    7
    RGB splitter - How will Aura detect devices connected to it ?
    Hi everyone,
    I posted this in the Strix boards section but got no reply so I moved it here.
    I'm planning to use 3 Cooler Master RGB fans and DeepCool Captain 240EX RGB AIO cooler (this cooler has RGB on the block and comes with a separate RGB led strip) with the ROG Strix Z370-E, all these are Aura Sync-compatible.
    So those are 5 RGB devices to connect to the board's RGB headers. However, there are only 2 normal RGB headers on the Strix Z370-E board, that means I will have to use 2 of these Cooler Master 1-3 RGB Splitter Cables in order to connect all those 5 devices to the board and control them with Aura. The 3 fans will be connected to RGB header #1 using one spliter, the AIO cooler's block and RGB strip wil be connected to RGB header #2 using another splitter.
    My question is: Will Aura detect devices connected to one spliter and RGB header as separate zones ? Or will it simply think they are just one RGB device/zone ? (As with the above set up, will the 3 fans be detected as 3 separate zones ?). And if Aura should detect them as one RGB device/zone, does that mean there's no way to set them to have their own color ?
    Thanks in advance.
    Banned Array JustinThyme PC Specs
    Laptop (Model)G752VY-DH72
    MotherboardRampage VI Extreme
    ProcessorI9 9940X
    Memory (part number)64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17
    Graphics Card #1ASUS Strix 2080Ti O11G @ 2.1GHz
    Graphics Card #2ASUS Strix 2080Ti O11G @ 2.1Ghz
    Graphics Card #3ROG Nvlink
    Graphics Card #4Have to feed animals
    Sound CardExternal Audioengine D1 24 bit 192kbps DAC
    MonitorASUS PG348Q @ 100Hz
    Storage #1Intel 905P 480GB U2 flavor
    Storage #2Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1
    CPU CoolerHeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS
    CasePhanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM
    Power SupplyCorsair AX 1500i
    Keyboard ASUS Claymore
    Mouse ASUS Spatha, Logitech MX Master
    Headset Sennheiser HD 700
    Mouse Pad ASUS ROG Sheath
    Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub
    OS Win10 Pro 1809
    Network RouterNetGear NightHawk X10
    Accessory #1 NetGear Prosafe 10GBe Switch
    Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
    Nov 2013
    144
    3,856
    One Zone per header. The RGB realm has just begun to delve into addressable devices and some MOBOs have addressable headers. The MOBOs LEDs are zoned, the GPUs LEDs are zoned, USB devices are mostly zoned, an RGB strip and fan is a dumb device that just takes 12V and varying intensities of R, G and B signals to do their thing, No fancy communications going on there. Everything on any given header will behave in exactly the same manner.
