Results 1 to 2 of 2
    ROG Guru: Yellow Belt Array Carbonicdk PC Specs
    Carbonicdk PC Specs
    MotherboardAsus ROG Strix Z370-E Gaming
    ProcessorIntel i7-8700k
    Memory (part number)F4-3600C16Q-32GTZR
    Graphics Card #1Asus ROG STRIX GTX1080TI O11G GAMING
    Sound CardSchiit Modi 2 Uber
    MonitorAsus MG278Q
    Storage #1Samsung 960Evo
    CaseFractal Design Define R6 - Tempered Glass
    Power SupplyCorsair Professional Platinum Series AX860
    OS Windows 10 64bit
    Mar 2016
    143
    Lightbulb What is your CPU overclock settings and results for 8700k
    So, for us noobs who havn't overclocked much all these Intel 8 gen voltage regularities and heat issues are hard to get around. Therefore, it might help to have a starting point, something to aim for and something to brag about.
    Please post in this thread a description of your overclock using the following format:
    • Motherboard & Bios version
    • Overclock
    • small/medium/maximum overclock?
    • What settings and values did you change from default bios settings to the overclock?
    • Cooling hardware + settings
    • Idle, gaming and 100% usage / stress temperatures + mention of thermal throttling
    Example:
    • Motherboard: Z370-E, bios: 0420
    • 4.8ghz all core
    • small overclock
    • Multiplier: 48 on all cores, vcore 1.26v, asus multicore enhancement: off, XMP: enabled 3200mhz
    • NZXT Kraken X62 280mm AIO with fans and pump set to performance mode
    • Idle: 27C°, 60C° when gaming and at 100% usage: 73C° almost immediately which caused thermal throttling down to 4.2/4.3Ghz
    New ROGer Array
    Oct 2017
    1
    Throttled
    Quote Originally Posted by Carbonicdk View Post
    • Overclock
    Example:
    • 4.8ghz all core
    • small overclock
    I don't think at 72 you are being thermal throttled check this thread https://rog.asus.com/forum/showthrea...Limit-Exceeded you are being power throttled turning MCE on and setting my voltage manually fixed that for me.
