Results 1 to 5 of 5
    New ROGer Array
    Oct 2017
    1
    Destiny 2 crashing - help needed
    Hi guys,
    As the titles says, I am experiencing crashing on Destiny 2 PC and need help. It isn't just crashing the game, it is taking my whole system down.
    HISTORY:
    From launch, the crashes have been sporadic. Some plays will be an hour (I think 2 was my most but that was a one off) and some can be as little as 2 seconds. I have tried everything that I can find or have had suggested to me on @BungieHelp Twitter and FB, also /r/Destiny2Support on Reddit:
    Re-installed Nvidia driver v.388.13
    Re-installed Windows update v.1703
    Disabled Game Bar
    Disabled Game DVR
    Scan and Repair done multiple times on D2
    Stress tested multiple times for 1 hour
    Tried all games on system at ultra – no crashes
    Run D2 as admin
    Run Battle.net as admin
    Power cycled network routers
    Played on all graphics setting from lowest to highest – it makes no difference and crashes are still random
    I have stress tested my system multiple times for an hour, one after the other and experienced no crashes. All other games played at Ultra setting have no issues and run at 50 - 80 FPS. D2 itself runs fairly consistently at 70 - 75 on highest settings.
    My main problem is that Bungie have offered zero assistance other than putting out a list of known errors and fixes, none of which are mine. I am not alone in this, but due to a lack of correspondence from them, Blizzard are not refunding me, saying that it has been too long since purchase. So I'm fuming, as the reason for the delay in asking was actually giving Bungie a chance to assist me.
    THE CRASH:
    Basically, it comes out of nowhere. There is no frame rate or performance drop. The game is capped at 75fps (to match monitor I guess) and has crashed at 75 multiple times. There has been no rhyme nor reason to it, if I get a crash after 2 seconds, hard reset my comp and relaunch the game, I could go for an hour or so before it happens again. There is no repeatability in it. I go straight to either black or white screen and whole system is unresponsive. I also do not get an error code.
    MY SYSTEM:
    G752VS
    i7-6700HQ 2.6Ghz - 3.5Ghz turbo
    16GB DDR4 RAM
    GTX 1070
    Win 10 Home - fully UTD - 1703
    Nvidia driver V-388.13 - UTD
    As mentioned, stress tests didn't crash anything, no other game crashes it or gives noticeable performance drops. I am at the end of my tether with this as they are refusing refunds.
    Is anyone else experiencing this? If so, did you find a work around/fix?
    PLEASE HELP!!
    iron man Array kkn's Avatar
    Aug 2011
    243
    6,129
    i would go and google and see if other have the same problem.
    do you get up a BSOD? if so whats the error shown??
    Nate152 PC Specs
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Power SupplyPCP&C Turbo Cool 1200w
    Mouse ROG Chakram Core
    Mouse Pad Steelseries QCK Prism XL
    OS Windows 11 Home
    Nate152's Avatar
    Feb 2013
    308
    16,631
    I was getting a few crashes here and there too, there has been a few updates since it released so maybe this will solve it for you. If you're overclocking, try running at default settings. I've been playing the last couple days crash free.
    In the game settings, video settings there is 30FPS cap, 60FPS cap and OFF for no cap which is 200FPS, where are you seeing 75FPS cap ? If you're forcing V-Sync on in the Nvidia control panel, try setting it to application controlled and use the in game V-Sync settings.
    You could do this for 75FPS cap.
    https://www.kotaku.com.au/2017/10/ho...-in-destiny-2/
    ROG Guru: White Belt Array CODE MAXIMUS PC Specs
    MotherboardMAXIMUS IX CODE • BIOS 1009
    Processor7700K • 4.5GHz
    Memory (part number)Corsair Vengeance LPX • CMK16GX4M2B3600C18 ver4.31 • 3866MHz • 15-15-15-36-2CR
    Graphics Card #1ASUS STRIX 1080Ti OC
    Sound CardOnboard • SupremeFX S1220
    MonitorASUS ROG SWIFT PG279Q
    Storage #1Intel Optane 900P 480GB
    CPU Cooler2016 EKWB Supremacy EVO • Acetal + Nickel • Straight Distilled Water
    CaseCORSAIR AIR 540
    Power SupplyEVGA Supernova 850W P2
    Keyboard HyperX FPS Alloy TKL
    Mouse SteelSeries SENSEI 310
    Headset Coolermaster Masterpulse
    Mouse Pad SteelSeries QCK Limited
    Headset/Speakers 100W BLACKWEB ZULU 2.1 • Soundbar + 8" Sub • TOSLINK
    OS WIN 10 64bit
    Network RouterNETGEAR X4S • Gigabit fiber optic connection
    Accessory #1 3X Corsair Magnetic Levitation 140mm PWM case fans
    Accessory #2 2X Corsair Magnetic Levitation 120mm PWM radiator fans
    Accessory #3 APC XS 1000 • Backup
    CODE MAXIMUS's Avatar
    Mar 2017
    42
    123
    Nate, when you were getting crashes did you make any changes to your system?
    Nate152 PC Specs
    MonitorHP ZR30w
    OS Windows 11 Home
    Nate152's Avatar
    Feb 2013
    308
    16,631
    Nope no changes, it's been running good for a while.
    I notice Destiny 2 doesn't like too much of a gpu overclock.
Tags for this Thread
