Aura Sync Problem
LonCoyLexTonDre
does anyone experiencing this?
when i open up my pc the sync is working properly but when i start playing games like OverWatch the sync will hang up or the lights will turn off..
my bios is updated already to the latest version.
maximus hero IX
strix 1060 OC 6GB
ROG Gladius II
ROG Claymore
this is so dissapointing >.<
7 REPLIES 7
MrAgapiGC
you have the new window update install?
Learn, Play Enjoy!
yep. just updated my OS to 1709 win 10 pro 64bit
just downloaded thelatest software of aura sync. the hanging still continous. 😞
actually i sync all of them but in a few minutes while on games or multitasking the sync will just hang >.<
Gofran
when this happens again can you remove usb of the mouse ? or keyboard but first gladuis ii because i kind have this issue also
when you do that it works from you?
namoi
It is a known more or less un acknowledged issue.
You will have to live with it until they solve it.
Do you have an Asus mouse? Or a devices which use Armoury?
yeah.. its annoying that you didnt get what you pay for.
AkaNe0
As Gofran and namoi asked, can you do the test without the ROG Gladius II plugged and see if your game and AURA run smoothly.
Note: Make sure that you also have the latest Armory with latest firmware updated on both ROG Claymore and ROG Gladius II
And don't forget, Keep pushing it !
